Is it possible to replace the plain vanilla look of the tool bar with an image file of the same dimension as that of the tool bar using the S/W like resource hacker. If possible plz tell me how to go about doing it.
Btw .. Thats not Toolbar .. Its Taskbar .. Toolbar tweaking is possible with YzToolbar .. For Taskbar you'll have to find some skinning option ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
