Old 13-09-2004, 05:33 AM   #1 (permalink)
144
144's Avatar
Default Hardware Problem! Require Immediate Assistance
I was playing Tribes 2 provided on this months Digit DVD; decided to max all Graphics options; was playing with FULL SCREEN disabled.
Just 1 min after these changes- The screen went blank. The green Led on my cabinet was on. But I could see it was not rebooting; switched it off and tried to boot up. IT wouldn't.
after re checking by switching on and on again, I decided to open up. I touched the heat sink which was hot. ( not extremely hot)
After a while i plugged it back and re tried.
This time, I could see that on my mother board there is a green LED which is ON. (Does this mean the mother board is not fried up; that it is fine?).
I tried to switch it on. It wouldnt. But occasionally the fans start working (both proccesor fan and Power Supply fan) for a second and die off. During this time the RED LED on my casing also comes on for a sec and dies off ( I assumed the hard disk also starts to work! )..
Here are my sys specs:
AMD Athlon XP 2400+
ASUS A7N8X Deluxe MotherBoard.
512 MB RAM 333MHz
Samsung SATA 80GB Hard ?7200rpm
Samsung 753DFX 17" Monitor
nVidia GeForce MX 440 64MB card 8x
Mercury 'Oscar' cabinet with a 300W power supply.
OS : Windows XP Pro
[NO UPS]
I have checked and recheked- All the cables are plugged in- No loose cards. All capacitors on the MainBoard looks fine. No smell of fry ups. No Smoke. I have a Surge Protector. And there were no Brown Outs. Room Temperature was approx 29 degrees Celsius.
My Question is :
Can it be a the malfucntioning of the M Board or the P supply?
Any help would be appreciated much.
Thanks
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 13-09-2004, 01:52 PM   #2 (permalink)
its must be the power supply
the mobo comes on atleast
ur just not gettin the juice to ur mobo
No Mercy, No Limits.
theraven is offline
Old 13-09-2004, 09:16 PM   #3 (permalink)
go step by step:
first try to clear the cmos then try starting : if it works fine, get a new battery maybe.
If its the power supply - disconnect all the cables except the motherboard from the power supply- then try to start. If your SMPS is weak then pc should boot. Then get a new smps.
Does your MB have a speaker, if you dont have connect one to the motherboard and check for any error beeps. these are explained in the manual.
I think the CMos thing will work.
(if youre lucky)
Victory breeds hatred, for the defeated live in pain. Happily live the peaceful, giving up victory and defeat.
oldmonk is offline
Old 14-09-2004, 06:15 AM   #4 (permalink)
144
144's Avatar
Default Solved it atlast
theraven and oldmonk; Thanks alot for your reply I appreciate the help.
I hv solved the problem. It was a faulty power cable. The power cable to my SMPS. Phew! What a relief.
cheers.
144 is offline
Old 14-09-2004, 12:25 PM   #5 (permalink)
club_pranay's Avatar
Default NO UPS???
R U NUTS??
dude, get your computer a ups...
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 15-09-2004, 05:00 AM   #6 (permalink)
144
144's Avatar
Yea right. I donno what I was thinking. Any suggestions on a good brand of UPS? I am thinking APC. How is that?
144 is offline
Old 15-09-2004, 01:34 PM   #7 (permalink)
APC is the best
theraven is offline
Old 15-09-2004, 02:12 PM   #8 (permalink)
JAK
What the Heck !
JAK's Avatar
Originally Posted by theraven
APC is the best
hmm...
Yup...u cant get anything better then that...
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
JAK is offline
