07-07-2005, 12:08 AM
Bad Sector
why the bad sector form in my hard disk
thanks for viewing my question
07-07-2005, 01:10 AM
The Hardware Labs
bad sectors can be formed due to various reasons such as improper shut downs , high temps , frequent power cuts (if you dont have a ups) , improper placement , mishandling , etc.
a hard disk is a very sensitive component and should be given the maximum care and attention possible.
07-07-2005, 05:58 AM
The No.1 Stupid
can anyone tell me , how to detect bad sectors in hard disk and how to remove them?
i m using windows XP professional
please tell the procedure
thanx in advance
BTW , this thread should be posted in Q n A section
so mods please do it
07-07-2005, 08:57 AM
Another Brick in the Wall
Moved here
07-07-2005, 09:10 AM
Bad sectors can be located and removed using the built-in chkdsk utility.
If you c drive is suspected, then go to command prompt and type:
If the drive is locked, then you will be asked if chkdsk can run after a restart. Say "yes", in that case.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
07-07-2005, 09:17 AM
MVP in VC++
Please try with the slow but best methdo i.e...... thorough System scan disk.and then with disk defragmentation..
07-07-2005, 09:20 AM
For info on how bad sectors form,
http://icarus.cc.uic.edu/~aciani1/sector_blues.html
If u are new to hard disks, you will find the following link good for easy reading:
http://www.storagereview.com/guide2000/ref/hdd/
07-07-2005, 09:26 AM
WinXP has chkdsk. Win98 has scan disk. And disk defragmenter has nothing to do here.
If u are talking about the
Drive-->Right-click-->Properties-->Tools-->Check Now
utility, that is the same as the chkdsk command at dos prompt.
Search this Thread |
