it displays connecting and doesn't conenct
whatz the problem
i waited even 14 mintes
it happens always
xp
version 6
internet is working fine
this always happnes
help me plz
no firewall
Dude...jus try login from Gaim, Trillian or any other third party messenger ..if you can login then probably you are on a continuous boot by someone ...or may be yahoo messenger server by your ISP ..but that is unreasonable .. you can try reinstalling Yahoo mess.
I Blog at - http://www.chinmayspeaks.com
dear DO not forget that yahoo messenger is still in its BETA Stage ?
i was also facing this problem some days before ?
there could be any other reason ? But they r just testing it
जय माता दी
It\'s Ok.... u r the best ,,,, i can speak more lie ,if u r happy with it,,, WWW.GOOGLE.COM is BIG BOSS !!!
जय माता दी
