Old 06-07-2005, 12:59 AM   #1 (permalink)
Default Yahoo messenger problem
Hai,
I think i have a peculiar problem. I dont get offline messages in my yahoo messenger when i login with a particular user id, but it works fine with all other yahoo ids. I dont know what caused the problem. Please help me out.
Thanx in advance,
with regards,
killer365
killer365 is offline
Old 06-07-2005, 07:19 AM   #2 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
1) Login with that ID...
2) Go to Prefrences ...
Check that all setting are ok ...
rollcage is offline
Old 06-07-2005, 07:46 AM   #3 (permalink)
alib_i's Avatar
its a common problem .. i dont think anything is wrong at your end ..
just wait for some time .. and probly yahoo will start behaving properly
more to read :
http://www.wackyb.com/zzub/index.php?showtopic=8061
http://au.help.yahoo.com/help/au/mesg/twin/twin-28.html
alibi
-Metallica
alib_i is offline
Old 06-07-2005, 07:52 AM   #4 (permalink)
if you are using the v7 u wont get offlines. it happened to me
'Veni, Vidi, Velcro\' - I came, I saw, I stuck around.
hyde is offline
Old 06-07-2005, 03:29 PM   #5 (permalink)
expertno.1's Avatar
@hyde
i have version 7 and i am able to get offline messages
expertno.1 is offline
Old 07-07-2005, 11:32 PM   #6 (permalink)
Default Re: Yahoo Messenger problem
I am keeping my messenger status online, but still i am not able to get my any offline messages and i always sign out before closing the internet connection and then then only i shut down down my comp or is there any long duration for which i have to keep my account online. or is there anything like the other user should also use the same yahoo messenger version. Please help.
with regards,
Killer365
Old 08-07-2005, 12:06 AM   #7 (permalink)
abhishekkulkarni's Avatar
No there is no such thing.
In fact if u install any other version below 7.0 it ( autoupdater ) automatically prompts you to install a newer version & logs out.So most probably everybody would be using v7.0 only.
Try installing it though if nothing works.
May the source be with you ..
abhishekkulkarni is offline
