| Forum |
#1 (permalink) |
Using default setings(100 Mhz external frequency) the cpu is identified as Athlon with 1.1 Ghz. I tried various combinations by changing the DSW switch on the mobo(as refferen in the manual). Now the external frequency is set at 166 mhz nd now it is recognized as a sempron 2600+@1.83 Ghz. It refused to boot when set to 200 mhz(the max the board can support). Can anyone tell me what should be the speed of a sempron 2600+? How can I set a value b/w 166 nd 200? There are 5 small switches on the DSW switch.On the manual there are only 4 combinations.The only option after 166 is 200. Now at 166 mhz the bus speed is only 332. |
#2 (permalink) |
The factory speed of AMD sempron 2600+ is 1.833GHz.
I haven't used your mainboard, so here's something about overclocking your cpu: http://www.xbitlabs.com/articles/cpu...on-2600_7.html
http://myxp.blogspot.com ----------------------- Winchester 3200+ @2,500MHz LeadTek 7900GT VOLT MODDED @ 680 core, 1800 mem 2x1GB Transcend DDR400 @ DDR454 2.5,3,3,5,1T |
#3 (permalink) |
Can i make it run at 400 mhz FSB?
Can I use 3rd party softwares to OC it(like fanspeed) Fan Speed allows on the fly overclocking within windows but my mobo is not in its list. What do I do? Is there any alternate utility? Also what should be the idle temp nd temp at maximum load for a sempron?
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#4 (permalink) |
For a Sempron the idle temperatures should be
Motherboard - 45C CPU - 55C Now u said that your Processor is running at only 166Mhz FSB.Thats too low.Implement Dual channel mode by fitting one more alike memory module and you will get large performance boost and FSB increases. |
#5 (permalink) | |
AMD 2600+ Sempron means 333Mhz FSB with 11 multiplier total running at 1833MHz AMD FAQ 333Mhz FSB means 166Mhz system bus speed. So there is nothing wrong. Putting dual channel memory does increase performance, but the said mobo doesn't support dual channel memory. Also dual channel will not increase bus speed or FSB as you are indicating. Please don't give wrong info, if you don't know what it means.
i generally prefer quality over quantity 1 aadi + 1 aadi = 1 full |
| Bookmarks |
| Display Modes | |
