Old 05-07-2005, 08:32 PM   #1 (permalink)
tuXian's Avatar
Default .:: Help Me Buy A Pen Drive ::.
Hi Guys I am planning to buy a USB Pen Drive either 128 or 256 MB.
I would like to know what should I look for before buying a pen drive.
Are there any benchmarks for it?
Did digit carry a shootout in the mag anytime??
Plz help me buy
You know it's love when you memorize her IP to skip DNS overhead.
tuXian is offline
Old 05-07-2005, 09:05 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Digit had them at agent001, check june/july 2005 issue.
USB pen drives prices:
64mb--> 650rs.
128 mb-->900rs
256mb -->1.6k
1gb--> 2.5-2.7k
Look these are not branded..so in case u want a branded one, it will cost more.
Also discussed here:
http://www.thinkdigit.com/forum/view...=201958#201958
drgrudge is offline
Old 05-07-2005, 09:57 PM   #3 (permalink)
i dont think u need to benchmark..
many brands are there like iball, transcend etc.. iball is cheap and sufficiend.. transcend is more expensive but established brand..
iball rates approx are 128 MB : Rs. 1000
256 : 1600
512 : Rs. 2800
all approx..
I\'M BACK
khandu is offline
Old 05-07-2005, 10:18 PM   #4 (permalink)
aadipa's Avatar
I just got Transcend JetFlash (TS1GJF2B) 1GB USB 2.0 @ Rs 4050
Came with 2 yrs warranty.
No idea about smaller size
1 aadi + 1 aadi = 1 full
aadipa is offline
Old 06-07-2005, 12:00 AM   #5 (permalink)
The Hardware Labs
mohit's Avatar
I am using Kingston Data traveler 512 MB USB 2.0 with 3 years warranty ... got it for 2500/- three months back. its gr8. wanna buy it ? log on to www.aainfoways.com
mohit is offline
Old 06-07-2005, 12:33 PM   #6 (permalink)
tuxfan's Avatar
What advantage does a pen drive have over a combo of memory card+USB card reader? I feel the combo is better becase you can use the card even in Mobiles, PDAs, DigiCams, etc. There's not even too much difference in costs.
tuxfan is offline
Old 06-07-2005, 03:06 PM   #7 (permalink)
The Hardware Labs
mohit's Avatar
The advantage of a pen drive will be the data transfer speed and also the size... a combo of a card reader and memory card will be bulky and will not be wirefree.
mohit is offline
Old 06-07-2005, 06:03 PM   #8 (permalink)
i need to get a XDcard USB drive.. any ideas?
to transfer images from my Fuji digicam to the studio.
Believing you can do it is half the work..Believe in yourself.
My cam sample pics
http://www.thinkdigit.com/forum/viewtopic.php?t=24414
plasmafire is offline
Old 06-07-2005, 11:24 PM   #9 (permalink)
Certified Nutz
sreevirus's Avatar
well, thats what i'm doing for now. i bought a transcend mmc card of 512 mb for 2.7k (with 5 years warranty). although its not as cheap as a pendrive, i think the warranty made up for the money. but then again, if u dont have a card reader, or a mobile phone with mmc/sd card support, then its just right to have a pen drive, ultra portable and really comes in handy (u cant use a card reader device as a key chain).
but just FYI, chinese made cards are available for cheap rates, albeit you cant get any warranty on them in most cases (a 1 gb NCP card cost me 3.1k).
transfer speed isnt affected for thumbdrives or card readers. the transfer rates remain the same depending upon the type of connection. it will be faster for USB 2.0 while slower than that for older USB ports.
there r card readers available that can read cards of various types (sd, mmc, xd, memory stick pro, etc. - some can read upto 10 types of cards). since you are moving to Powai, just inquire a bit. sorry, but i have no idea about the cost.
"Don't take life too seriously. You'll never get out alive!" - Bugs Bunny
sreevirus is offline
Old 07-07-2005, 04:47 PM   #10 (permalink)
@sreevirus i don't need a card reader.. just an XD usb drive without the card.. with a reader, i can only connect by using propreitary drivers.
My cam sample pics
Old 07-07-2005, 05:13 PM   #11 (permalink)
tuXian's Avatar
@plasma whats this XD USB Drive, how it works? How much does it cost??
tuXian is offline
Old 07-07-2005, 05:35 PM   #12 (permalink)
i just know about card readers.. 19-in-1..
can read XD cards also and are plug n play in XP..
hardly 400 bucks in maket.. i use it.. excellent..
I\'M BACK
khandu is offline
Old 07-07-2005, 06:01 PM   #13 (permalink)
tuXian's Avatar
i am more confused now
tuXian is offline
Old 08-07-2005, 08:59 AM   #14 (permalink)
http://www.fujifilm.co.uk/digital/ac...ory.php?id=404
Phew...got a link ..herezz what it looks like
do check out my review of the cam http://www.thinkdigit.com/forum/view...=214029#214029
My cam sample pics
Old 08-07-2005, 10:45 AM   #15 (permalink)
that is also a card reader which can just read XD card.. and are much more expensie..
but y not go for the 19-n-1 ?? much much cheaper that that and can read much more media.. and is USB and plug n play in Windows XP
I\'M BACK
khandu is offline
Old 08-07-2005, 12:29 PM   #16 (permalink)
how does the 19 in 1 look like khandu? pocketability is also an issue. + this needs no drivers on any OS except 98
My cam sample pics
Old 08-07-2005, 12:43 PM   #17 (permalink)
Looks like
dosent need driver for XP.. cd is provided for 98.. cant say about linux
without the extension cable its pretty small.. fits in palm..
I\'M BACK
khandu is offline
Old 08-07-2005, 01:03 PM   #18 (permalink)
tuxfan's Avatar
My card reader looks pretty similar (including the curves and lights ) Its very small and lights. Its as big as about 6-7 credit cards kept together on top of each other.
It gets recognised in Mandrake 10.1 and PCQLinux 2005 (based on Fedora Core 3) without any problem.
It gets recognised in WinXP too, but Win98 was a problem. The accompanying CD didn't carry the right drivers. Then after some struggle, I got hold of 4 files on net that makes it work well in Win98 I have saved them safely. So if anyone needs it, contact me. Files are pretty small. I can even email them.
tuxfan is offline
Old 08-07-2005, 06:13 PM   #19 (permalink)
hey khandu, the reader in the pic ios HUGE.. larger than a CD.. come on man..
if u find a pen type reader tell me.. XD alone will suffice
My cam sample pics
Old 08-07-2005, 06:41 PM   #20 (permalink)
no no not at all..
its smaller than a CD.. fits in a palm.. the size is exact as compared to my ICICI Debit card..
I\'M BACK
khandu is offline
Old 09-07-2005, 03:19 PM   #21 (permalink)
tuxfan's Avatar
Actually, the pic contains the reader as well as its sorrounding packing. All that is blue is just paper. What is in silver is the actual card reader. khandu is right (and so am I ). Its as big as a few credit cards stacked one above the other. Smaller than my palm and fits even in my shirt pocket.
tuxfan is offline
Old 09-07-2005, 04:02 PM   #22 (permalink)
tuXian's Avatar
guys saw an ad in a tech mag which speaks about 25 in 1 ...
BTW if I purchase these in 1's then I think I have to purchase a memory card seperately.
Which is the cheapest and best card that can be used in these in 1's.?
tuXian is offline
Old 09-07-2005, 11:18 PM   #23 (permalink)
cheapest is simple MMC card.. u can get 512 MB around Rs. 1800
i dont think there is much diff in the top one and 25-in-1.. dont know which extra cards the 25-in-1 read..
I\'M BACK
khandu is offline
Old 10-07-2005, 02:05 AM   #24 (permalink)
bang bang!
Chirag's Avatar
Go for LG 512 MB
i am using it with no problem
EDITosted: Sun Jul 10, 2005 2:06 am
With LG u also get cd for 98, no wire needed in XP
Long cord to join Pen Drive with Cpu and cheap cost
EDITlease use the edit button instead of posting a new reply.As I can clearly see the time gap between your replies was 1 minute.Please refrain from doing this - digen
Chirag is offline
Old 10-07-2005, 01:14 PM   #25 (permalink)
tuxfan's Avatar
Instead of MMC card, why not take SD cards? Cist diff is about Rs. 100.
Card readers may say they are 25-in-1. But are there 25 types of cards available?
tuxfan is offline
Old 10-07-2005, 02:45 PM   #26 (permalink)
i thought MMC are cheaper than SD
I\'M BACK
khandu is offline
Old 10-07-2005, 06:47 PM   #27 (permalink)
tuXian's Avatar
ok guys I can go in for a reader.
BTW one of my frnd is only interested in Pen Drive 128 MB and wants to know which one is best of these:
1. Kingston
2. Transcend
3. i
4. MSI
Plz lemme know
tuXian is offline
Old 10-07-2005, 06:50 PM   #28 (permalink)
alib_i's Avatar
from my limited knowledge : transcend
alibi
-Metallica
alib_i is offline
Old 10-07-2005, 07:17 PM   #29 (permalink)
iball is cheapest i guess and very reliable..
best would be Sony Microvault or Transcend
I\'M BACK
khandu is offline
Old 10-07-2005, 07:25 PM   #30 (permalink)
tuXian's Avatar
any idea how much sony costs. Is it easily available in India
tuXian is offline
