Old 24-11-2009, 12:59 PM   #1 (permalink)
Quick Shooter
phanisrinivas's Avatar
Default Removal device problem??? Please help!!
I have Zen Stone Plus player...
Once I was not click safely remove , i removed quickly..
Next , when I connect the device , it was not open ...
" dailog window" shows like "Disk Drive is not formatted, Do you want to format it".. then i click "Yes"
Again t shows " The disk in drive <> cannot be formatted"
1. In command prompt " format H: -> It shows " Insert new disk for H: drive, and press enter when ready"
2. I used HP Disk Format tool for formatting " in that the device cannot be found"
3. I use Creative firmware tool, that was also shows " device was not found"
Is there any hotfixes for removable devices ...
PLEASE HELP
Posted again:
Please help??
Last edited by phanisrinivas; 24-11-2009 at 01:05 PM. Reason: Automerged Doublepost
phanisrinivas is offline
Old 24-11-2009, 02:05 PM   #2 (permalink)
Default Re: Removal device problem??? Please help!!
well, i think you need to try this tool
and here there's a firmware for your player.
i hope this helps.
adityaxone is offline
Old 24-11-2009, 02:20 PM   #3 (permalink)
Quick Shooter
I already tried that tool..
It shows " searching the device" but In MyComputer shows device.. but for formatting.. it cantt
---please help
Old 24-11-2009, 02:38 PM   #4 (permalink)
Quick Shooter
please help
Old 24-11-2009, 03:12 PM   #5 (permalink)
Quick Shooter
hello anyone know this problem???
Old 24-11-2009, 04:30 PM   #6 (permalink)
Quick Shooter
please help
Old 24-11-2009, 07:28 PM   #7 (permalink)
CA50's Avatar
Boot from ubcd, given with digit. There are many hdd tools. Use those to format ur mp3 player
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 24-11-2009, 07:41 PM   #8 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Yup....!! Try what CA50 said. I think this will solve ur problem.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
ubuntu getting crash again and again contactpraven2001 Open Source 16 12-03-2008 05:09 PM
I/O error while copying some data on to external HDD gary4gar Open Source 4 02-11-2007 12:31 PM
Problem with Pinnacle PCTV-Stereo puttu Hardware Q&A 4 15-06-2007 05:40 PM
SEVERE Overheating Problem... akash_bhavsar Hardware Q&A 6 17-11-2006 11:11 AM
K3B says device busy-cannot burn disks unni Open Source 11 07-10-2006 04:01 PM
