| Forum |
#1 (permalink) |
I am going to buy a new PC AMD 64 bit 3000+(939 pin).I have decided to buy the ASUS A8N-E motherboard.But it is not available with the dealer.When I contacted Rashi thru my dealer the said that it is "out of stock" in MUMBAI .So I should choose another mobo.Please tell me another mobo having the nForce 4 ultra chipset.I dont want the ASUS A8N-SLI mobo as it is a waste of money(i am using only one gra: card).Wat abt MSI K8N NEO 4 PLATINUM http://www.msi.com.tw/program/produc...il.php?UID=637 What abt its perfomance when compared to ASUS A8N-E? Will this mobo support my AMD 64bit 3000+(939 pin)? Can I connect my 5400RPM PATA HDD to this mobo(MSI)? What is the price of MSI K8N NEO 4 PLATINUM? |
#2 (permalink) |
MSI K8N NEO 4 is an excellent option. Just ask your dealer for an opinion on MSI support. Returns, warranty replacements/repairs etc.
Keith
[ THIS SPACE HAS BEEN RESERVED FOR FUTURE USE IN CASE I WANT TO BOAST ABOUT MY PC'S, HOUSE, CAR, GIRLFRIENDS OR OTHER STUFF THAT I KNOW YOU DON'T REALLY CARE ABOUT ] |
#4 (permalink) |
I absolutely would recommend MSI K8N Neo4 platinum over Asus A8N-E. MSI's board is excellent for I/O and overclocking. It's internal sound card is also less cpu cycle stealing. I don't think msi has a pci-x x1 slot. Please verify this.
MSI K8N Neo4 has received a lot more editor's choice awards than asus a8ne. Can u tell me the price that you were offered it for? BTW, I have an Asus A8N-E.
http://myxp.blogspot.com ----------------------- Winchester 3200+ @2,500MHz LeadTek 7900GT VOLT MODDED @ 680 core, 1800 mem 2x1GB Transcend DDR400 @ DDR454 2.5,3,3,5,1T |
#5 (permalink) | |
which of the above two is recomemeded if both are available?
NOBODY is PERFECT and i am NOBODY |
#6 (permalink) |
Sorry man, but the info about sound card and I/O was bit of a news to me. Back then, MSI's only strong point I knew was it's overclocking ability.
If both are available, choose according to the price. The difference I quoted would be too small to notice to a moderate user anyways.
#8 (permalink) | |
Prices will differ. Pick up the phone, open your yellow pages and make some calls to local pc shops. -Keith
#10 (permalink) |
The Hardware Labs
Both MSI and ASUS are good. but ASUS has a better network for service , so go for it. Also I think ASUS A8N-E will be cheaper. This asus board has some compatibility probs with Corsair RAM so stay away from Corsair.
#11 (permalink) |
MSI neo 4 platinum , it's the best. ASUS have a known issue with their fans. Many people have reported that they have some fan problem in their A8NE motherboards. It makes loud noises and sometimes stops working.
#13 (permalink) |
No experience recently, But in the old days Asus quality was not very good. I had a couple of dual CPU boards I have used as a BBS server. The price was really cheap at the time, only around $500. Compared to other dual CPU boards from HP, DEC. IBM etc which were in the 2K range. So thats the only reason I got the Asus. Quality wise MSI was always much better and also costlier... I still use an MSI Pentium pro that has 5 dual LED's that shows the loading sequence, this will let me know when it locks up where it locked up at. Like bad memory, bad drive, cant load operating system etc. The packing, manuals and everything from MSI was much niftier... But like I said the cost was higher... I just ordered an MSI RS480 mother board.. That is the 939 package with the built in GFX
I think Asus became big with the AMD cpu's? They were never well known back then and you did not really buy their stuff if you had the choice.. Which was why I had so much trouble finding their stuff, it was usually still packed in the box at the bottom of the shelves. |
#14 (permalink) |
why can't you take 2 modules of xms instead of 4 and ot take value select
of corsair with this mobo also isn't asus a8n-e supposed to be amongst the best ocers out there,may be better or equavilent to msi and almost as good if not equal or something to dfi with a8n-e
Core i7 2600k|Gigabyte P67A UD4 B3|Corsair XMS3 2x4GB|HD6970|Coolermaster SilentPro 850M|Coolermaster HAF 932|Audioengine AE5|Samsung Galaxy S|Samsung Galaxy Tab 3G|Blackberry Curve 8520 |
#15 (permalink) |
I too ma getting the MSI neo4 Platinum along with 3500+ veniece CPu. The cost is Rs 8500 for the mobo and 14000 for the cpu in bangalore 3200+ CPU is for Rs 9500/-
The MSI board is much better than the ASUS nforce 4 ultra board it has utilised all the 20 pci-e channels verry well and gives one pci-e x1 and a pci-e x4 (actually a x2) slot which gives a throughput of IGbps. Also the two gigabit lan give amazing throughput as they are not on the pci bus .
**** happens |
#17 (permalink) |
Nope.
I would stick with Asus. MSI boards are having problems in installing 2 7800GTX cards on their SLI boards,Asus doesnt seem to ahve any such problem. Also on the MSi board you mentioned,Vdimm is ONLY 2.85V Whereas on Asus its 3.0V You dont expect less than 3.0V on a performance board,do you ? |
#18 (permalink) |
ASUS ne time.
Becoz of its gr8 service network. Havent seen many people getting MSI here. But ASUS Rulez for me too. No Onboard GPU Option is there for any NF4 Based Mobo.
Overclock Me. Overvolt Me. AMD Me. |
#19 (permalink) |
asus a8n-e - probs with corsair value select and other rams
pls check user guide or manual
| Bookmarks |
| Display Modes | |
