Old 12-09-2004, 08:23 PM   #1 (permalink)
Default need help verrrryyyy urgent!
i am using a system with intel celeron 810e processor with128mb ram running widows 98se.whenever i try to play games in my pc it shuts down after sometime i started the game.then i have to reboot.this happens every time.i need help.
ponni is offline
Old 12-09-2004, 08:35 PM   #2 (permalink)
Check your system temperature settings using mother board monitor
Update to the latest DirectX version, and make sure you get the latest graphics drivers from intels site ...
BTW, which games do you try to play? Modern games wont run on that system.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 14-09-2004, 01:25 PM   #3 (permalink)
tuxfan's Avatar
Go to Start > Run and type dxdiag. It will bring up the DirectX Diagnostic Utility and let you see if something is wrong with your directX installation. Even of nothing is wrong, it is alwwya advisable to upgrade to the latest compatible version.
tuxfan is offline
Old 14-09-2004, 10:04 PM   #4 (permalink)
busyanuj's Avatar
Default Re: need help verrrryyyy urgent!
your system is probably low on Virtual Memory.
increase the Virtual Memory and check again.
and do install the latest Direct X 9 c drivers.
busyanuj is offline
Old 14-09-2004, 10:18 PM   #5 (permalink)
abhishekkulkarni's Avatar
There is only one solution for this ----
Remove all cabinet covers.I mean from all sides.Your PC is probably in the corner of a room or something & away from the window.If this is so ( or if not ) take a table fan and place it parallel to the cabinet.
And that should do it.Also compare the Motherboard Voltage Levels from the manual.
May the source be with you ..
abhishekkulkarni is offline
Old 15-09-2004, 05:04 AM   #6 (permalink)
144
144's Avatar
Which game are you trying to play?
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
