Old 19-11-2009, 03:14 AM   #1 (permalink)
Question Need help for buying a server....
I need to run a windows based simulation software for my research work. It takes about 4 hr to complete the simulation on my AMD Athlon 2800+ with 1GB DDR400 RAM running on win xp sp2 platform. I want to complete the above simulation in 1 hr. Pls recommend server(s) for the same. You may notice that the main requirement is processing speed, not the reliability or the fail safe architecture of the server. If the multiple desktop can be connected to do the same, then give me the info. of the service providers who can do this.
sushantasarkar is offline
Old 19-11-2009, 07:47 PM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: Need help for buying a server....
turn your attention to xenon processors and 16gig of ram
better still look for XC1 Cray system or IBM server solution.
Posted again:
sorry,, XT1 and XT3 systems cray
Last edited by arpanmukherjee1; 19-11-2009 at 07:49 PM. Reason: Automerged Doublepost
arpanmukherjee1 is offline
Old 19-11-2009, 10:32 PM   #3 (permalink)
Any comment on blade servers....pls..
Old 20-11-2009, 09:18 AM   #4 (permalink)
XLr8
from useage you propose (bring down processing time from 4 to 1 hr.) multiple blades are to be used. this sort of computetation i presume will be much more costly than other server solutions
Old 20-11-2009, 01:18 PM   #5 (permalink)
Post Re: Need help for buying a server....
This server will b purchased by university with a max budget of abt 10 lakh including the charge for the os and installation. will it be sufficient for multiple blades.
Posted again:
I have zeroed on IBM System x3455 ...is it ok ?
Posted again:
Last edited by sushantasarkar; 20-11-2009 at 01:21 PM. Reason: Automerged Doublepost
The Archlinux thread abhinandh Open Source 89 19-07-2008 07:20 AM
One Giant Command Line MetalheadGautham Open Source 23 24-05-2008 02:31 AM
Techniques to Hide One's Identity on Internet _mAkA_ Tutorials 12 17-08-2007 01:50 PM
Facing problem in configuring yahoomail with outlook... Here is the solution... anmol004 Tutorials 35 09-03-2007 05:53 PM
Turning your PC into a Web Server [lokesh] Tutorials 9 21-07-2005 06:54 PM
