For DVD to .avi :
Use
DVD Decrypter
DVD Decrypter is a free tool that allows you to decrypt and copy DVDs to your PC's hard disk. From there you can watch them with the likes of WinDVD and PowerDVD, you can write them back to DVD-R / DVD-RW / DVD+R / DVD+RW / DVD+R DL / DVD-RAM media or you can convert them to VCD / SVCD / DivX for burning onto CD-R / CD-RW.
DVD Decrypter can write most types of CD / DVD images via its 'ISO Write' mode, and it supports all the latest writers (including booktype / bitsetting on many of the major ones - i.e. BenQ, LiteOn, NEC, Plextor, Sony). You can even use DVD Decrypter to erase / format your rewritable media!
How to do:
1. Get DVD Decrypter (Freeware)
http://www.dvddecrypter.com/
2. Get autoGk (Full pacakge) (Free)
http://www.autogk.me.uk/modules.php?name=Downloads
3. First use DVD Decrypter to rip the VOB file from your DVD and save them into a folder.
4. Now open up auto GK...and locate the directory where u've saved the .VOB files...and now u have the option to rip to whatever size...since u wanna rip to 1.37 GB (2 CDS) or 700mb ,tick that option....and then change the other settings if u wish..and hit RIP!!
Note the ripping speed depends on the PC speed and it's performance. Get autoGK only u have a faster computer.
