Old 05-07-2005, 10:34 AM   #1 (permalink)
Default Pros of PHP
Why is PHP a good language & how is it better than other most used languages [except for the reason that it is free]?
Think about it!
Trinity is offline
Old 05-07-2005, 10:44 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
1. PHP is open source. So development is fast.
2. PHP is very easy. If u know C, u know 90% of PHP.
3. PHP is platform independant. Since it is browser based.
4. PHP is very powerfull. Can do almost everything that any other language does!
Regards,
Kalpik
kalpik is offline
Old 05-07-2005, 07:36 PM   #3 (permalink)
alib_i's Avatar
i would also like to add that PHP has a very large collection of extremely well thought-off functions which can allow to do anything you want !
php's functions are very good
being open source is very helpful
alibi
-Metallica
alib_i is offline
Old 06-07-2005, 01:01 PM   #4 (permalink)
tuxfan's Avatar
Is that so? Are you sure?
I knew quite a bit of C and can pick up from where I left a few years ago. I am very eager to learn PHP.
tuxfan is offline
Old 06-07-2005, 03:50 PM   #5 (permalink)
alib_i's Avatar
yeah .. the format is very similar.
ex. if-else condition statements, loops, etc
if you know C, you'll find PHP very easy
alibi
-Metallica
alib_i is offline
Old 06-07-2005, 05:54 PM   #6 (permalink)
kalpik's Avatar
Hi tuxfan!
Yeah, PHP is *VERY* similar to C! Well have a look at the documentation section at http://php.net to get started! Ill be happy to help if u need any help regarding this!
Regards,
Kalpik
kalpik is offline
Old 07-07-2005, 06:02 PM   #7 (permalink)
tuxfan's Avatar
Hi tuxfan!
Regards,
Kalpik
Thank you so much. Can you please tell me from where I start?
tuxfan is offline
Old 07-07-2005, 06:45 PM   #8 (permalink)
kalpik's Avatar
Hi!
Well first of all, u nees a web server since PHP is a server side language. Get apache server from http://apache.org
Then u need the PHP binaries. Get them from http://www.php.net/get/php-5.0.4-Win.../from/a/mirror
Then extract php-5.0.4-Win32.zip to the folder where PHP will be installed, C:\PHP is a good choice. Then read the install.txt in this zip. Yeah! I know its a bloody LONG file! Well the important sections are the starting intro and "Apache 2.0.x on Microsoft Windows
" topic. Read it throghly! Also it will contain info about configuring your php.ini file. Read it too.
Then install Apache server. And edit the httpd.conf file according to the info in the install.txt file in the php package.
Woah!
Do this n then let me know!! Hehe
Kalpik
kalpik is offline
Old 08-07-2005, 08:46 AM   #9 (permalink)
abhishekkulkarni's Avatar
Even I am doing what you have suggested.Please guide me ahead.
May the source be with you ..
abhishekkulkarni is offline
Old 08-07-2005, 11:17 AM   #10 (permalink)
kalpik's Avatar
Default Configuring PHP with Apache.
Hi!
Actually, configuring PHP with Apache is the *most* tedious job i've ever done! Ill maki it easier for u guys. Download Apache from http://apache.org and install it with the defaults. When it asks for domail name etc, enter "localhost" in the first 2 boxes and enter ur email address in the third.
Now download PHP from http://www.php.net/get/php-5.0.4-Win.../from/a/mirror
Unzip it to C:\PHP.
Now download http://www.kalpik.5gigs.com/php.zip
This has 2 files. Extract php.ini into C:\PHP and httpd.conf into C:\Program Files\Apache Group\Apache2\conf
Replace all existing files.
Now, u will have a leaf type icon in your system tray with a green "play" button on it. Left click on it and select Apache2 -> restart. U will see several warnings about a file php_mysql something. Just keep pressing ok.
now goto start -> run -> services.msc
Here double click on Apache2 and change startup type from automatic to manual.
Now right click My Computer, select properties. Go to the advanced tab and click "Environment Variables" Now under "System Variables", there will be a value named "Path", double click on it.
Now if the variable value is ending in a ";" (semi colon), its ok otherwise, put a semi colon and write "C:\PHP;C:\PHP\ext" (Without quotes) over there. Select ok to exit the dialog box.
Now restart.
After restart, u will have the apache icon in ur tray with a red "stop" button. Click on it select Apache2 -> start. Now u should not see any warnings if everything is configured correctly.
Now open your browser and type "localhost" or "127.0.0.1" in the address bar. A page of Apache should open. If it opens, CONGRATS! U have succesfully configured Apache with PHP! Otherwise get back to me!
Try this and let me know!
Take care!
Kalpik
kalpik is offline
Old 08-07-2005, 11:27 AM   #11 (permalink)
kalpik's Avatar
Direct link for Apache (incase u r not able to find it!)
http://www.signal42.com/mirrors/apac...x86-no_ssl.msi
kalpik is offline
Old 08-07-2005, 12:07 PM   #12 (permalink)
tuxfan's Avatar
Actually, I have PHP+MySQL enabled server space So I can directly use it for initial trial and error. I have downloaded the documentation yesterday and have just started reading. Will make a simple "Hello World" PHP application today and proceed further from there.
Any suggestions/tips?
tuxfan is offline
Old 08-07-2005, 01:09 PM   #13 (permalink)
kalpik's Avatar
Its really good u have ur web space! Configuring PHP is a pain in the @ss!!!
The PHP manual is the best thing to learn PHP from. But be sure to read it from the begining otherwise maybe u wont get it!
Take care!
Kalpik
kalpik is offline
Old 08-07-2005, 01:16 PM   #14 (permalink)
tuxfan's Avatar
Thanks for the tip. I have just started reading it
tuxfan is offline
Old 08-07-2005, 02:41 PM   #15 (permalink)
alib_i's Avatar
best php editor i've seen is PHP Edit
you can try that too ..
alibi
-Metallica
alib_i is offline
Old 08-07-2005, 05:01 PM   #16 (permalink)
I am also a PHP-Lover
Lovedeep Wadhwa
cheetah is offline
Old 08-07-2005, 06:34 PM   #17 (permalink)
siriusb's Avatar
Thanks to this thread, I'll have one more language in my resume. Let's PHP!
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 08-07-2005, 07:33 PM   #18 (permalink)
Version 2.0
Deep's Avatar
I strongly wont suggest replacing php.ini or httpd.conf
checkout my tutorial here....
http://www.thinkdigit.com/forum/viewtopic.php?t=15502
anyways back to the topic...
i had started php with ebook called teach urself php on 24 hrs...i read 3-4 chapters (till functions or classes i suppose) and then i couldnt stop myself so just started off with it and took help of manual and google..
if anyone needs some books on php then let me know, i have some stuff on my server, i can share..just PM if u need it
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 08-07-2005, 07:42 PM   #19 (permalink)
kalpik's Avatar
Hey! Deep!
Was just trying to help! And make thinks as easy as possible! You can download and see for urself the httpd.conf and php.ini files i posted! Nothing illegal dude!
Anyway, good tutorial!
Kalpik
kalpik is offline
Old 08-07-2005, 07:44 PM   #20 (permalink)
Version 2.0
Deep's Avatar
Hey! Deep!
Kalpik
oh, No, I didnt mean illegal stuff...
I just meant about version differences...
sometimes they make changes in ini and conf files in new versions...
so better to use default one and edit the settings if needed...
btw glad to hear that you liked the tutorial
Regards
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 08-07-2005, 07:52 PM   #21 (permalink)
kalpik's Avatar
Hi!
My files were according to the latest version of Apache (2.0.54), PHP (5.0.4) and Mysql (4.1.12)
Well, have made a suggestion for ur tutorial! Check it out in your tutorial thread!
Kalpik
kalpik is offline
Old 19-07-2005, 11:59 AM   #22 (permalink)
Default php editor
the link to alib's suggested php editor is
http://www.waterproof.fr
try it out
Think about it!
Trinity is offline
Old 19-07-2005, 04:24 PM   #23 (permalink)
Hi friends!
This one is an excellent thread..thanks to whoever created it!
[b]i want to know if a digit like forum can be created with php after learning php basics?
(i've heard of phpBB and used the freeBB site)
[\b]
i really (might i say desperately) want to learn how....
i'll be greatful if you people can help!
thanks
A flea and a fly in a flue, were caught, so what could they do? Said the fly, \"let us flee!\" \"Let us fly!\" said the flea. So they flew through a flaw in the flue.
technovice is offline
Old 19-07-2005, 05:04 PM   #24 (permalink)
kalpik's Avatar
The phpBB forum is NOT basic PHP! It includes sessioning, mysql, and god knows what not! Not an easy job if u ask me! Anyway, u can try!
kalpik is offline
Old 20-07-2005, 12:23 AM   #25 (permalink)
hafees's Avatar
i m studying PHP with mySQL. as i know C, PHP is easy to learn. I relly liked it. I have a bought a book that teaches PHP5 and mySQL5. PHP5 supports object oriented programming as any other OOP language.
i tried some free hosts that supports PHP. I found siteburg.com but it is ad supported (a forced ad on top of every page. ) Also they do not support PHP5 or mySQL 5.
If someone can suggest a truely free PHP host with
latest version that ll be really helpful
hafees is offline
Old 20-07-2005, 08:12 AM   #26 (permalink)
kalpik's Avatar
Try http://www.5gigs.com
kalpik is offline
