Old 05-07-2005, 12:26 AM   #1 (permalink)
mekalodu
iinfi's Avatar
Default which platform do i select?
i m thinking of Downloading Solaris 10 frm sun.com
it may take a month or two to download though
its 2.5 GB and i m planning to download the CD format and not DVD since i have no DVD burner ...
this is the link frm where i m gona download http://www.sun.com/software/solaris/get.jsp
what i need to know is, there is an option saying "Select Platform" ....
there are 2 options given there
a) SPARC
b) x64/x86
which option sud i select ....??
mekalodu
iinfi is offline
Old 05-07-2005, 01:22 AM   #2 (permalink)
busyanuj's Avatar
the SPARC option is for SPARC servers.
the x64/x86 refers to the standard version for PCs, download it.
busyanuj is offline
Old 05-07-2005, 10:39 AM   #3 (permalink)
mekalodu
iinfi's Avatar
ok man
thanks for ur help.i will start downloading the x64/x86 one right away.
btw what are SPARC servers?
mekalodu
iinfi is offline
Old 05-07-2005, 02:33 PM   #4 (permalink)
SPARC servers are servers running on 32 & 64 bit processors.the only difference is that they are RISC (Reduced instruction Set Computing). processors.These are different from the Intels,AMDs we use(they are CISC or
complex instruction set computing).
RISC processors are used for high end applications and that too only for specific applications which demand a lot of processing power and speed.
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 05-07-2005, 07:33 PM   #5 (permalink)
mekalodu
iinfi's Avatar
oh!! thanks for da info ...
mekalodu
iinfi is offline
