There is nothing wrong with your UPS( i guess it is giving u backup above 15min)....
When we switch on monitor its DEGAUSS is activated ... which clears magnetic waves
..And DEGAUSS takes above 1kV...that's why UPS is resetting power supply ..
(when monitor woke up from standby DEGAUSS is not activated.)
So.. here is solution for ur prob...
In Power Option properties(under screen saver option) ... set monitor power off timing to 1 min(after 1 min monitor will go standby)...save setting(press OK)..
Now u can put monitor off at night(use monitors power button)...
But when u want to switch monitor on ... first switch on the monitors power button...
the monitors light will glow orange ( as it is in standby mode)... now move mouse... monitor will came out off standby without restarting CPU.....
Posted again:
When we switch on monitor its DEGAUSS is activated ... which clears magnetic waves..And DEGAUSS takes above 1kV...that's why UPS is resetting power supply ..
