Old 04-07-2005, 02:45 PM   #1 (permalink)
Default A CD with 4-5 GB of DATA
Hello friends, Now dis wud be amazing to read or may be already discussed in forum but i have one CD (Mind u not a DVD) that has all 10 different versions of Windows 2003 server on it, and it is also a bootable CD.
Now wen i copy the disk content to my HDD is takes 4-5GB disk space, But the disk space is 698 MB in properties. I m wondering dat how 4-5 GB of data is stored on a normal 700 MB Compact Disk . A direct cd to cd copy can be made of dat CD.
So freinds please tell me how to do such a gr8 job coz if we cn do dis we will never need a DVD isn,t it?
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 04-07-2005, 02:49 PM   #2 (permalink)
Just Do It
Charley's Avatar
Maybe it could be compressed.
But its really strange that , in a CD how can GB's be stored.
Hoping other users can explain this..
Charley is offline
Old 04-07-2005, 03:18 PM   #3 (permalink)
DUDE send me one copy!
abhinav is offline
Old 04-07-2005, 03:33 PM   #4 (permalink)
godsownman's Avatar
Yes I have read this here in the forum only.
Suprisingly this person who had this CD also had all the windows OS's loaded on it.
Please if somebody knows please let me know
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 04-07-2005, 04:14 PM   #5 (permalink)
It's no magic of compression blah blah...Its quite simple. There is an MS Office 2003 CD which is a All-in-One CD which shows the so called 4GB of data. Thats is mainly because Microsoft Word points to set of common files used by it which is the same as frontpage, VISO and so on. And each is just linked to the file and does not have the file as such. Hence each thinks it has a full installation with all the files available to it only. Hence u get this massive 4-5gb file size.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 04-07-2005, 04:16 PM   #6 (permalink)
Yes i too have read this before
i think topic was "extent of overburning"
please search it to clear your doubts.
Techmastro is offline
Old 04-07-2005, 06:24 PM   #7 (permalink)
nope u can't overburn it to GBs.. i think the record is ~900 MB on 700MB CD..
The CDFS is edited to show multiple logical copies of a single physical file.. quite simple really. also used for copy protection.
in this case, i guess the program needs many similar files in the install dir of every windows, so they have made logical copies in the same directories by manually editing the filesystem.
BTW, the CD is illegal..so don't advertise
Believing you can do it is half the work..Believe in yourself.
My cam sample pics
http://www.thinkdigit.com/forum/viewtopic.php?t=24414
plasmafire is offline
Old 04-07-2005, 09:50 PM   #8 (permalink)
q3_abhi's Avatar
I got a CD which consisted of Rise of Nations n Rise of Nations: Thrones n Patriots full !!!! Now how can that be possible?? It was PKZipped!!!!
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 04-07-2005, 10:34 PM   #9 (permalink)
expertno.1's Avatar
@q3_abhi
well pk zip is a compression utility which compresses the files
so u can get 1000 mb's to be compressed into 400 mb's or less
well
Winrar has the ebst compression na ?
expertno.1 is offline
Old 04-07-2005, 11:15 PM   #10 (permalink)
Well if u see.. MYTH rips..
Now they compress games to 200-300 MB
What they do is remove all unnecessary files like video/ clips etc.. and then use a software called UHARC .. this software can do a very high compression.. mp3 is a diff data pack and others in a diff data pack..
u see any modern pirated CD.. 80% will be using UHARC compression..
It takes a lot of time to compress..
And if u talk about windows CD.. use nlite to remove all extra component and use UHARC..
just removing all extra languages can reduce 100 MB ur Windows installation CD ..
I\'M BACK
khandu is offline
Old 04-07-2005, 11:29 PM   #11 (permalink)
expertno.1's Avatar
well virtual cd is a good cd copying utility with compression
it emualtes the compressed images..how its done
can anyone tell me
Old 04-07-2005, 11:33 PM   #12 (permalink)
deepak_m's Avatar
it was in digit that some company which starts with 's' (Samsung?,sanyo?)is releasing a cd-rw which can write about 4GB of data onto a normal 700mb cd!
deepak_m is offline
Old 04-07-2005, 11:36 PM   #13 (permalink)
can anyone tell me
Use Alcohol 120% .. A CD/DVD Drive emulator and best in market.. can easily copy and rewrite it onto another CD/DVD..
I\'M BACK
khandu is offline
Old 05-07-2005, 12:29 AM   #14 (permalink)
I read the previous post and found the answer.. well thankz to every one who replied and i hav also found how we cn create such kinda CD's with common files..
Please refer following links to kno how we cn make those CD's
http://www.msfn.org/board/lofiversio...hp/t45270.html
AND
http://www.msfn.org/board/index.php?showtopic=39994
Old 05-07-2005, 12:36 AM   #15 (permalink)
aadipa's Avatar
Its a symbolic links.. ie as said by icecoolz and plasmafire
It was also discussed few times earlier.. see
http://www.thinkdigit.com/forum/viewtopic.php?t=14764
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
