Old 04-07-2005, 02:33 PM   #1 (permalink)
QA Juggler
saROMan's Avatar
Default How to do this...????
Ok i have 3 images whose background is blue and i wanna convert them to Transparent/White ..so how can i do that ???
The images are..
Or else if some one can make them white i will be really greatfull...
One more thing....
When ever i try to save a icon as bmp/jpg/gif/png ..the transparent area turns to black...is there any way / soft thru i can mentain the transparency of the image ???
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 04-07-2005, 02:42 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
u can use photo shop laso tool.... & there is plugins in photo shop to make ICON....
Choto Cheeta is offline
Old 04-07-2005, 02:45 PM   #3 (permalink)
QA Juggler
saROMan's Avatar
Well bro..i i knew how to do it in photoshop why wud i Post it here
saROMan is offline
Old 04-07-2005, 03:06 PM   #4 (permalink)
Rebooting
lol... sorry dude... yes if u have knew then u havent post it in the 1st place.... yup... sorry...
Old 08-07-2005, 01:07 AM   #5 (permalink)
Hanging, since 2004..
tarey_g's Avatar
here are ur transparent background images ,(btw its very easy , use lasso/magic wand tool of adobe pshop) .
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 08-07-2005, 11:29 AM   #6 (permalink)
NikhilVerma's Avatar
These one's are a lil antialiased...
Well jpg and bmp don't support transparency...
png does... And it will always save as transparent... Try that again...
When saving as gif check the transparent checkbox in the saving options...
NikhilVerma is offline
