I'm thinking of using Antec’s Fusion Remote as the cabinet but in the existing setup, I may need to then place it vertically -- ie, have it stand on its ~5" side although like a typical amplifier its base is ~17" wide.
** Is this positioning ok for this cabinet?
** Where & how should the ventilation be facilitated, in this position?
** Is there any problem with using it this way?
Also I find Antec Fusion Remote, Antec Fusion Remote Max, etc in the net -- what is the difference between these? And which is recommended for a HTPC? (Similar to Agent 001's recommendation in Oct '09 Digit issue).
Would like your feedback on this...
Thanks & Regards,
Shankar
