Old 26-10-2009, 05:56 AM   #1 (permalink)
Revolution's Avatar
Question How To Install Application On Memory Card ?
Do anyone know how to install application or games on phone's memory card ?
I have Nokia 2700 Classsic and using PC Suite 7.1.
Every time I selected destination for installation memory card from drop down menu but no work.
Application and games always installed on phone memory.....
Revolution is offline
Old 28-10-2009, 11:28 PM   #2 (permalink)
CA50's Avatar
Default Re: How To Install Application On Memory Card ?
Simple man i hav got da same cel. Instead of installing using pc suite, connect ur cel in data storage mode n copy da jar n jad files to da mem card. Simple isnt
Posted again:
Hey man hav u checked the review of da handset on net? They say dat da set has got 64mb internal memory but i m geting 30mb. What da hack man?
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 29-10-2009, 05:42 AM   #3 (permalink)
Revolution's Avatar
Unhappy Re: How To Install Application On Memory Card ?
I got only 27mb memory.....
Old 29-10-2009, 07:43 AM   #4 (permalink)
CA50's Avatar
its ok man i got 2 mb more then u.
I hav got a prob i password protected my mem card n i forgot the password. How can i get my password? now i cant access my card not even in pc
| Nokia 2700c |
CA50 is offline
Old 29-10-2009, 05:16 PM   #5 (permalink)
ramprasad's Avatar
Google for 'Memory card password crackers'.
I am not supposed to give anything illeagal on the forum.
PM me
I am not sure whether this works, but give it a try. Try to put the mem card in a card reader and try to access it.
Regarding ur actual question, just copy and paste the .JAR file to a folder in ur mem card
ramprasad is offline
Old 30-10-2009, 05:37 AM   #6 (permalink)
Revolution's Avatar
Thanks...
Copy-Paste actually works on my phone.
Old 30-10-2009, 09:55 PM   #7 (permalink)
CA50's Avatar
OK dude............
| Nokia 2700c |
CA50 is offline
