Old 03-07-2005, 09:14 PM   #1 (permalink)
rachitboom2's Avatar
Default PIO mode instead of UDMA mode 2 !!! PLS. HELP ME !!!
Hi everybody !!!
I have a Sony combo drive (master) and a normal Samsung CD ROM drive (Secondary) running on IDE 2 and I use XP Pro,
My problem is that I am not able to enable UDMA of my Combo Drive where as my other CD ROM is still running in UDMA mode 2.
Earlier it was running on UDMA mode 2 but suddenly one day I was just going through the device manager and I saw that it was running on PIO mode !!!
I have tried to do it using software, changing the IDE cable, turning UDMA mode on in the BIOS also and making it Secondary in both IDE 1 as well as IDE 2 but no affect !!!
Earlier I was able to write a CDR in just 2 min but now it takes me atleast 7 to 8 Min !!!
What to do ???
Pls. Help me !!!
Pls. Reply Soon !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Console: Xbox 360 Arcade 250GB
Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
Old 03-07-2005, 10:32 PM   #2 (permalink)
Check the bios. Under the primary/secondary master/slave (wherever ur cd rom is installed) check that the udma 2 is selected. this should solve the problem
geek is offline
Old 03-07-2005, 11:33 PM   #3 (permalink)
Use DMA forcer 1.2 --- google it for download as it is illegal to give outside links here.
Mahesh Babu is offline
Old 04-07-2005, 10:23 AM   #4 (permalink)
Dude I have already done it and havent you read the complete post, I have already mentioned in it !!!
I was not able to find any software called DMA forcer 1.2 in Google !!!
Pls. mail me the link at => Rachitforum@yahoo.com .
Pls. Reply Soon !!!
Old 04-07-2005, 11:53 AM   #5 (permalink)
Try the following. It has previously worked for me.
Right click on the IDE Channel in Control Panel > System Properties > Hardware > Device manager, where your cd writer is connected. Click on Uninstall. It will ask you to confirm. Click Yes. Now close control panel and reboot your system. You will find that the IDE channel is running in UDMA mode.
paraman is offline
Old 04-07-2005, 06:16 PM   #6 (permalink)
alib_i's Avatar
actually, wht happens is that when CD drive encounters CRC errors, it reverts back PIO mode.
a good option is to uninstall the device , and then install it again
but it'll turn to PIO again when it faces more CRC errors
PIO mode is enabled by default in the following situations:
For repeated DMA errors. Windows XP will turn off DMA mode for a device after encountering certain errors during data transfer operations. If more that six DMA transfer timeouts occur, Windows will turn off DMA and use only PIO mode on that device.
In this case, the user cannot turn on DMA for this device. The only option for the user who wants to enable DMA mode is to uninstall and reinstall the device.
Windows XP downgrades the Ultra DMA transfer mode after receiving more than six CRC errors. Whenever possible, the operating system will step down one UDMA mode at a time (from UDMA mode 4 to UDMA mode 3, and so on).
look at this page: http://www.michna.com/kb/WxDMA.htm
and microsoft's page for this: http://support.microsoft.com/kb/817472/
these pages have good info !
alibi
-Metallica
alib_i is offline
Old 07-07-2005, 04:08 PM   #7 (permalink)
Hi everybody and thanks for helping me !!!
But still none of your ideas helped me,
So I thought if uninstalling the drive dosent help then why dont I remove the drive itself and make my CD ROM as Master and and reset the CRC,DMA,etc settings and it worked !!!
When I connected my Combo again after a day it was again running on UDMA mode 2 !!!
Still Thanks for your Help !!!
Old 19-08-2007, 10:11 PM   #8 (permalink)
M$™ Certified Spammer
entrana's Avatar
Default Re: PIO mode instead of UDMA mode 2 !!! PLS. HELP ME !!!
1.right click on mycomputer- device manager u know
2. find the ide/atapi driver thingee that is ur burning drive usually its primary
3. if its says pio uninstall the driver
4. restart windows and its gonna reinstall drivers under udma there
as easy as 1-2-3-4
woops sorry didnt see the date of the thread
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
