Re: Lapotop within a budget of 45-50k
I believe the Macbook is around 55k... It has 13.3" screen and if net surfing and movie viewing are your main requirements, it should fit the bill...
Arun
Edit: If your requirements are only net surfing and movie viewing, you can go for one of the better netbooks which will also satisfy the 12" screen requirement... These cost around 25-35k which will save you some cash, but may not be great for long term requirements. If you are interested, I will check and inform which one is better.
