Old 10-10-2009, 06:45 PM   #1 (permalink)
vikasg03's Avatar
Default can we format c drive
I have window xp proff sp2 in c and d drive both partition. Now from d drie i want to format c drive to install xp again. but it wont allowed me to format. Is it possible
Vikas
vikasg03 is offline
Old 10-10-2009, 11:36 PM   #2 (permalink)
Project Halcyon V2.0
tkin's Avatar
Default Re: can we format c drive
U can't because the OS is probably running from the C drive. Use XP install disc to boot up and format C drive and re-install Xp, all your installed softwares will be deleted, even if they are installed on other drives they won't work, you need to reinstall them.
PS-To format C drive from D you need to first boot to the XP that is installed in your D drive even that might not work always. Best is to use XP install disc.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline
Old 22-10-2009, 12:16 PM   #3 (permalink)
ramprasad's Avatar
is it a dual boot sys...?
If so, try to boot into the OS installed on D:
To check which is the correct option to boot, Right click 'My Computer'-->Properties -->Advanced --> Startup and Recovery Settings
ramprasad is offline
