Old 03-10-2009, 12:08 PM   #1 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Question Some Silly Questions
1. Intel Pentium D @ 3.0Ghz
a. Is this the clock speed for each core?? Or its the summation of speed for both the cores??
b. If yes does this theory apply for C2D, Quad Core and other range of AMD and Intel Processors??
2. Is thr any DMA mode for SATA DVD Drive?? If yes how to enable it?? Does SATA DVD Drives r treated as IDE Drive??
3. +12v1 : 15A
+12v2 : 16A
Does this mean I hav 31A in +12v channel?? And I can use high end graphics card?? Or the process of calculation of this type of two +12v rails r different??
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 03-10-2009, 03:27 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Some Silly Questions
for 1.a and b, answer is yes, really unsure about 2 and 3
My site: collegeclassroom.org
amitash is offline
Old 03-10-2009, 07:13 PM   #3 (permalink)
Simply a DIGITian
wow..!! sum1 replied atleast..!! Thnx Amitash...
Old 03-10-2009, 08:08 PM   #4 (permalink)
Simply a DIGITian
Hey ny more reply???? sum1 plz reply......
Old 04-10-2009, 01:24 AM   #5 (permalink)
GOD
vaibhav_jain's Avatar
Lightbulb Re: Some Silly Questions
answer for third question?
yes you are right it is 31A for 12V channel but you can`t use it for high end card. i think you can use these 12v rails with two low end cards in sli or crossfire combination, also remember use cards which requires less power from the 12V channels according to their capacity(i.e. 12V).
Posted again:
Vaibhav Jain
Last edited by vaibhav_jain; 04-10-2009 at 01:26 AM. Reason: Automerged Doublepost
vaibhav_jain is offline
Old 04-10-2009, 01:35 AM   #6 (permalink)
GOD
Arrow Re: Some Silly Questions
question 1. a. answer!!
in my view it is the sum of speed of all the cores, not for the individual core(i.e. 2.5GHz quad core means having the total speed of 2.5Ghz of all the 4 cores, but the main point here is that this processor has 4 cores which can work individually at the same time, and in past processors there is only single core like P4 3.0GHz, it has only single core to operate therefore quadcore with 2.5Ghz of speed is much more powerfull than P4 with 3.0GHz of speed).
Posted again:
Vaibhav Jain
Last edited by vaibhav_jain; 04-10-2009 at 01:35 AM. Reason: Automerged Doublepost
Old 04-10-2009, 08:55 AM   #7 (permalink)
Crowman
Krow's Avatar
But the performance gains of multi-core CPU's will not translate exactly to 2xSingle core in case of a dual core mainly because apps not being coded for multicore optimisation. All the same, each core has a clock speed of 3.0GHz yes!
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 04-10-2009, 09:23 AM   #8 (permalink)
Simply a DIGITian
Okz thnx..........
And wat about SATA DVD Writer?? Does SATA DVD Writer's hav DMA??
Last edited by krishnandu.sarkar; 04-10-2009 at 09:37 AM. Reason: Automerged Doublepost
Old 04-10-2009, 10:09 AM   #9 (permalink)
Wire muncher!
infra_red_dude's Avatar
These are actually very good questions, definitely not silly!
This is the fastest speed at which each stage in the processor pipeline runs. So in layman's term, this is the speed at which each core runs.
Yes
There is a DMA engine built into the controller. So you don't haf explicit control over the DMA setting for a SATA drive. No wonder it is so fast!
http://h20000.www2.hp.com/bc/docs/su.../c00301688.pdf
3. +12v1 : 15A
+12v2 : 16A
No, you cannot add the currents from 12v rails if both are not connected to the same sink. In fact, only the high end power supplies are dual rails. Most low-end and mid-range PSUs just split the 12v line to limit the current per line.
Theoretically, the maximum current you can get per line is (Power * efficiency)/Voltage. So lets say you have a 600W PSU, assuming a hypothetical efficiency of 60%, the maximum current on the 12v line is: 600 * 0.60 / 12 = 30A. This is assuming there is no drop in the other 5/3.3v lines.
But this is the peak current and NOT the sustained current in normal operating temperatures. The numbers that you indicate 15/16A are usually the guaranteed currents each line can supply under normal operating conditions.
http://forum-en.msi.com/index.php?PH...&topic=77071.0
http://forums.vr-zone.com/hardware-a...12v-rails.html
http://www.tomshardware.com/reviews/...er,2122-6.html
infra_red_dude is offline
Old 04-10-2009, 10:20 AM   #10 (permalink)
Simply a DIGITian
Hey WOW......!! Tats gr8.....!! Very simple describing....!!
Thnx yaar....!!
