Old 03-07-2005, 01:03 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Default CCleaner HELP!!
hi i have CCleaner installed ...
1.20.118 is the version .....
in CCleaner >> Tools >> Uninstall >>> programs to remove ..... there is a program New.net Domains 6.38 ...
i never installed anything like that ..... the control panel doesnt show the program .....
any idea what this is?? i uninstalled it thru CCleaner but it has come back
mekalodu
iinfi is offline
Old 03-07-2005, 01:39 PM   #2 (permalink)
hey dis is an adware, ven i had installed some games 4m da digit cd, the setup contained dis new.net****** ..... , so if u might hav installed dose games, new .net***** .... might hav crept in. just uninstall it from add/remove progs or download any anti addware/spyware/thiefware software.
by da way me 2 in navi mumbai, cbd...
dkd903 is offline
Old 03-07-2005, 03:05 PM   #3 (permalink)
mekalodu
iinfi's Avatar
oh... thanks for the info .... And i m frm New Panvel ...
mekalodu
iinfi is offline
Old 03-07-2005, 04:37 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
yep. new.dot.net is spyware. running microsoft ant-spyware AND adaware shud sole ur problem. i say run two, bcoz no single anti-spy ends up removing all the rgistry entries, etc. if u jus uninstall it, some elements cud still remain.
for more details click http://www.doxdesk.com/parasite/NewDotNet.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 04-07-2005, 03:13 PM   #5 (permalink)
Just Do It
Charley's Avatar
@ iifi - After u scan and clean the spyware , then if it still exists in the CCleaner , u can delete the registry entry in the tool[ccleaner], it should be removed the next time u revisit CCleaner.
Charley is offline
Old 04-07-2005, 03:15 PM   #6 (permalink)
mekalodu
iinfi's Avatar
ok thanks everyone ....
mekalodu
iinfi is offline
