Old 03-07-2005, 06:57 AM   #1 (permalink)
vignesh's Avatar
Default Desktop woes
I installed autopatcher last time and now there is no username shown on the top of my start menu.The icons on the desktop have colour under the icon name.How do make it back to clear type with no colour behind.
vignesh is offline
Old 04-07-2005, 01:34 AM   #2 (permalink)
I'm back!
Default The Solution
Open ur Registry from START > RUN > type "regedit" > ENTER.
Find th Key "HKEY_CURRENT_USER\Software\Microsoft\Windows\Curr entVersion\Policies\Explorer".
Delete the "NoUserNameInStartMenu" Value in the right pane, if it exists.
Setting it's value to "0" has th same effect.
Do th same for th Key "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Cur rentVersion\Policies\Explorer".
You may have to restart your PC for changes to take effect.
To make th background of ur desktop icons transparent follow th steps outlined by me in one of my earlier posts. Click Here.
Little Knowledge is Dangerous but a lot of Ignorance is just as Bad!
Minimalistix is offline
