Old 03-07-2005, 04:13 AM   #1 (permalink)
Default How to change the MAC Address of NIC card manually?
Mahesh Babu is offline
Old 03-07-2005, 01:41 PM   #2 (permalink)
it is very much easy...
Jus follow these steps...
1) Go to the Local Area Connection Icon
2) Right Click and select the properties..
3) In the properties.. In the general tab u will see ur Lan card listed on the first line
eg. D-Link DFE-538TX 10/100 Adapter
and next to it will be the configure button click on it!!!
4) In the new window go to the advanced tab
5) In tht from the list box showin property,select the Network Address
6) Now put the desired MAC Address in the Value Field next to it...
and voila ur Mac address has been changed...
and ya remember to restart ur computer before proceddin wid ur changed settings...
Enjoy!!!
Ai yo!!
maVen is offline
Old 03-07-2005, 05:14 PM   #3 (permalink)
Can we put any number in that field?
like 023000500000
Old 03-07-2005, 06:52 PM   #4 (permalink)
A Mac address is a 48-bit[6 byte] & 12 digit hexa decimal number hard coded into the NIC,so just replacing that with "anything" wont do.
www.Oobertech.net
digen is offline
Old 03-07-2005, 08:49 PM   #5 (permalink)
So i have to enter a valid MAC address i.e. MAC ID of another network card
Old 03-07-2005, 11:35 PM   #6 (permalink)
Yeah I believe or a valid hexdecimal number[dont count on me on this one though].
But may I ask what exactly you want to achieve by doing that?
www.Oobertech.net
digen is offline
Old 03-07-2005, 11:59 PM   #7 (permalink)
Thanks for the info
Old 04-07-2005, 06:36 AM   #8 (permalink)
siriusb's Avatar
Not all NIC cards allow changing of mac addresses. For them u have to use some external utility. Here's a free one:
http://www.softpedia.com/get/Network...c-Makeup.shtml
Some ISPs like SIFY, use MAC based authentication on their servers. Maybe this kind of auth is new, but my friend at mambalam (chennai) was under such system. I don't know exactly what happened, but I think he got into trouble after installing IPv6 tunnelling prtocol on XP and XP had reported some strange mac address instead of the h/w one. The trouble came with installing linux, which reported the nic's mac and hence was not authenticated on the ISp server.
He had to ask for resetting of mac address for his account. He could very well have used a mac address spoofing utility on linux and programmed the mac address reported by xp. But he got rid of XP itself in favour of linux
siriusb is offline
Old 04-07-2005, 06:08 PM   #9 (permalink)
I use Easy$ify dude..try it out..it is not hacking.
u can put any MAC ID in it
Believing you can do it is half the work..Believe in yourself.
My cam sample pics
http://www.thinkdigit.com/forum/viewtopic.php?t=24414
plasmafire is offline
Old 10-07-2005, 05:15 AM   #10 (permalink)
MAC Spoofing huh.. u can change from registry or using kmac..
Mostly u can use for arp spoofing. once done it can be used to divert the packets from the switch & re route to the destination IP..
PraKs is offline
