Old 19-09-2009, 05:02 PM   #1 (permalink)
rayne's Avatar
Default HDMI/DVI on my PC
I have ASUS m3a78em board and a Viewsonic e2200hd monitor.
The board has 3 outputs via HDMI/DVI/VGA and the montor has the same for input.
I've plugged in all 3 cables, and currently I'm in VGA mode.
I want to know how to switch from VGA mode to either DVI or HDMI ??
can anyone help? thanks in advance.
Cmdmt. XI: Thou shalt not inflict upon me thy useless prattlings, for I thy God am a busy God.
rayne is offline
Old 20-09-2009, 09:57 AM   #2 (permalink)
rayne's Avatar
Default Re: HDMI/DVI on my PC
no one?
rayne is offline
Old 20-09-2009, 03:08 PM   #3 (permalink)
swatkat's Avatar
What happens when you connect only DVI (from motherboard) to DVI (display)?
http://swatrant.blogspot.com/
swatkat is offline
Old 24-09-2009, 11:37 AM   #4 (permalink)
Are you sure it is Viewsonic and not BenQ? Whichever it is, there ahould be an option in your Monitor’s (On-Screen Display) Menu to select the input. Select the one you want. All monitors these days are intelligent enough to detect the one that is connected and take that. So, connect any one of them. You don’t have to connect all. HDMI is the best option which gives great clarity and sound with a single cable.
otpsurvive is offline
