Old 19-09-2009, 07:22 AM   #1 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Unhappy Exhausted after searching MB
Tell me any motherboard which has good life for AMD Athlon II X4 620 for 3k
I am exhausted really exhausted for searching mb on the net. I'm asking for mb for 3k because i reached my budget limit. My current config is
AMD ATHLON II X4 620 2.60GHZ
Western Digital 500GB
Transcend 2GB DDR2 800MHz
Altec Lansing BXR 1121
Zebronics Red Power 500W
APC 550VA
Zotac 9600GT 512MB
A cheaper mb will do for me..please...
IronCruz is offline
Old 19-09-2009, 10:33 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Exhausted after searching MB
increase that budget by just 1k and you will have much better options.
desiibond is offline
Old 19-09-2009, 05:51 PM   #3 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Which of the following is the best? Also tell me whether it is compatible with AMD Athlon II X4 620 proccy....
Foxconn A7GM-S
ASUS M3A78-EM
MSI KA780G
MSI KA780GM2
ASRock A780GMH
GIGABYTE GA-MA770-UD3
ASRock K10N78M
ASUS M4A78 Plus
Suggest some more....if available... i dont want a hi-fi type...a good value@3.5k and good life will do.....
please
IronCruz is offline
Old 20-09-2009, 11:42 PM   #4 (permalink)
AMD - Aaja Meri Darling
Dont worry much , the AMD Athlon II X4 620 is backward compatible with socket AM2+ motherboards.
ASUS M3A78-EM retails at 4.5k
Just add 1k more as desiibond said, seriously.. you'll have much more to choose from.
ASUS, GIGABYTE, MSI & Biostar all are in 4-5k range.
IMO, if your budget really cannot be increased anymore, you can do with ASUS M3A78-EM's onboard graphics as its decent enough. And throw in an ATI card (which come cheaper ) later on. Also try to put in a better power supply down the line. The quad core requires a better power supply than substandard stuff offer.
How much is your total budget exactly ?
Xeno is offline
Old 21-09-2009, 10:14 AM   #5 (permalink)
Biostar TA790GXBE is available for 4K and is a 790GX board with a very good IGP!
hell_storm2006 is offline
