Old 02-07-2005, 02:45 PM   #1 (permalink)
Default help needed on video capturing in dvd format
hiii guyzz can any one help me in finding a software to capture videos using a tv tuner card in dvd format so that it can me directly written into a dvd instead of first capturing it in mpeg n then converting to dvd...i have a pinnacle tv tuner card and i have tried using pinnacle stud0 9 but the video gets stuck.. plzzzz hell me out
i love my computer
san85 is offline
Old 02-07-2005, 04:06 PM   #2 (permalink)
Default Re: help needed on video capturing in dvd format
DVD's use MPEG2 compression for video. You will have to AUTHOR a DVD using this video and audio (ac3,dts,wav,mp2) sub tracks and menus.
Here's a previous post on a similar discussion. Read my last post at the end of the page.
http://www.thinkdigit.com/forum/view...=22706&start=0
Go read the guides at www.videohelp.com
-Keith
Keith Sebastian is offline
Old 11-07-2005, 04:03 PM   #3 (permalink)
dIgItaL_BrAt's Avatar
u can use windvr3 from intervideo,in the recording profiles select PAL DVD,then click modify,in audio options select the encoding option as dolby digital.Now u can record in MPEG2 with AC3 audio.Keep in mind that the AC3 encoding puts quite a strain on ur system so don't even think of multitasking.
dIgItaL_BrAt is offline
Old 13-07-2005, 01:40 PM   #4 (permalink)
just try the snagit new version it allows u
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
