Old 02-07-2005, 07:21 AM   #1 (permalink)
tweety_bird_bunny's Avatar
Default an extra hard-disk.........???? how to attach a 5th one????
hi.....
i have a HP cd-writer, dvd rom, lg writer with a 16GB harddisk....
but as all of u know lust for more is human nature... so i wanna shift to 80GB HDD.... but the problem ariirves here..... i donot wanna remove any of my previous 4 drives & wanna attach the 80 gb hdd as well....
SO, what shuld i do to get loaded with 5 of these things.....??
i have p4 1.8 ghz, 256 sd ram,win xP......
tweety_bird_bunny is offline
Old 02-07-2005, 11:00 AM   #2 (permalink)
Well its none of my business but why do you need two cd writers,HP cd-writer & a lg writer may I ask?
Anyways to solve your problem you could get a PCI to IDE Controller.It sits on your regular PCI slot.I'm not aware of the cost.
Here is a pic giving you a clear idea,again via google images:
http://images.tigerdirect.com/skuima...1018-main2.jpg
I would like to warn you though,the more devices you put inside a chassis the more worse the air circulation will be.I hope you have a adequate cabinet along with cooling fans to take care of heat.Just my 2 cents.
www.Oobertech.net
digen is offline
Old 02-07-2005, 11:59 AM   #3 (permalink)
NikhilVerma's Avatar
There are also external HDD connectors avaliable...
But they work like a USB drive... So they are slow...
NikhilVerma is offline
