Old 11-09-2009, 09:21 AM   #1 (permalink)
Exclamation speed fundaa??
my connection speed is 256kbps means 32kbps downloading speed but how can i get 265 kbps downloading speed sometimes.......
toqeer is offline
Old 11-09-2009, 09:08 PM   #2 (permalink)
Default Re: speed fundaa??
You cant get 256KBps download speed unless you switch to a 2mbps connection.
Sometimes you may get 256kbps by a mistake commited by your service provider like this guy
http://www.thinkdigit.com/forum/show...89&postcount=9
Aspire is offline
Old 11-09-2009, 10:26 PM   #3 (permalink)
Crowman
Krow's Avatar
@ toqeer Your connection speed as told to you by your Internet Service Provider is 256kbps or 256 kilobits per second. Now 8 bits = 1 byte. So actual speed you get is 256/8=32kBps.
As aspire said, if you need 256kbps download speed, u need to get a 2mbps connection, which is going to cost you quite a bit.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
