Old 01-07-2005, 11:49 PM   #1 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default MHT FILES NOT OPENING
Whenever I try to open mht files with IE an error comes. Here is the screenshot.
navjotjsingh is offline
Old 02-07-2005, 06:16 AM   #2 (permalink)
expertno.1's Avatar
do the file exists ?
and does the mht file is corrupt ?
have u typed the name incorrectly to open it ?
it says there is no such file !
check it if u have the file already or may be its corrupt
expertno.1 is offline
Old 02-07-2005, 09:05 PM   #3 (permalink)
I am Optimus Prime
Yes the file exists and it opened in the past. This problem is suddenly started showing. File is not corrupt. I double clicked the file - no error in file name.
Old 03-07-2005, 03:37 PM   #4 (permalink)
i think ur Codec is Corrupt !!!
Re-install !!
Cheers !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 04-07-2005, 09:49 PM   #5 (permalink)
I am Optimus Prime
Do you know what a codec is. MHT files are html files to be opened with IE or Firefox. Codec is for audio/video files. Poles Apart.
