Old 01-07-2005, 10:06 PM   #1 (permalink)
Default How 2 convert a .tmp file 2 its original extension?
I had downloaded a movie clip of size 26.3 MB with the help of DAP 5.3. when the download completed, dap dint change the output file 2 .mpeg format. rather the format was .tmp. Now how can i view the movie which is stored in this file.
dkd903 is offline
Old 01-07-2005, 10:20 PM   #2 (permalink)
alib_i's Avatar
try changing the extension to .mpg. it sometimes work !
go to folder options -> view -> uncheck hide extensions of known file type
now just rename the file to a .mpg
see if that helps
alibi
-Metallica
alib_i is offline
Old 01-07-2005, 10:36 PM   #3 (permalink)
thanx alibi, ur suggestion worked, thank u vry much.
dkd903 is offline
Old 02-07-2005, 06:24 AM   #4 (permalink)
expertno.1's Avatar
this happens when dap is not ur default dm and you just pasted the link of downlaod to it
use dap 7.4 the better and best one
update it
expertno.1 is offline
Old 02-07-2005, 01:31 PM   #5 (permalink)
Just Do It
Charley's Avatar
update it
What has that got to do with the query
and BTW I'd like to know r u a marketer for the prod, seems like it.
Charley is offline
Old 02-07-2005, 09:34 PM   #6 (permalink)
Ashwin Saxena
Posts: n/a
No he is not a marketer but DAP is really good.
I am also a dap user.
And it is the best downloader.
I swear....
