First open a folder.....goto Tools>>Folder Options
Click on the View tab....
Uncheck the Hide File Extensions for Known File Types option....
Now goto the folder where u saved that file and check if it has some extension like.......zip, .exe , .msi , etc....
If it doesnt have any extension then try adding some extension and try to run the file....
Just add a Dot followed by extension like .exe or .msi
Try these extensions...
EXE
MSI
ZIP
RAR
or goto the webpage where u downloaded that file and see the extension there....
Lovedeep Wadhwa
