Old 02-09-2009, 05:33 AM   #1 (permalink)
Default i want to add 1.5 or 2 tb hard disk, will power supply support
i want to add 1.5 or 2 tb hard disk, will power supply support this big hard disk.
i have currently 3 hard disks and i dvd writer and no graphics card or other thing
i have 400 watts iball power supply
i want to add 1.5 tb hard disk can there be power supply problem for this big size hard disk ,
i will add ony ide not sata hard disk.
i have 300 gb , 20 gb , 80 gb harddisk currently , if there is power supply problem i can remove maximum 1 harddisk that is 20 gb . mine computer is pentium 3.0
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 02-09-2009, 08:14 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: i want to add 1.5 or 2 tb hard disk, will power supply support
Go for Western Digital Caviar Green series HDD. They are pretty good at power saving and I think a 400W should easily drive these HDDs.
make sure that you backup important data as HDDs these days are facing lot of crashes.
desiibond is offline
Old 02-09-2009, 11:18 AM   #3 (permalink)
hell boy
Go on add any hdd! U wont have any problems
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 02-09-2009, 07:39 PM   #4 (permalink)
HDD's hardly consume much power! So not a problem. But just as an advice change ur PSU. If you have a good GPU then especially change it!
hell_storm2006 is offline
Old 02-09-2009, 11:27 PM   #5 (permalink)
why they face crashes , any reason or because they are of huge capacities 1 tb . i am afraid where to backup 1 or 1.5 tb data that i will put on that huge harddisk
Posted again:
u mean graphics card .
if u mean that i dont have graphics card .
AMIT AGARWAL
Last edited by AMITAGARWAL02; 02-09-2009 at 11:30 PM. Reason: Automerged Doublepost
Old 03-09-2009, 12:18 AM   #6 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
HDDs crash because they hv mechanical(moving parts) like the read write headers and spinners...
if u dnt want any crashes, then opt for SSDs = Solid State Drives, but they are (at this very moment) damn costly.. so unless they become mainstream, its no use buying them..
Go for WD HDDs, they are solidly built for performance..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 06-09-2009, 03:34 AM   #7 (permalink)
but i am using 320 gb harddisk from more then 1 year and no problem at all. are new hard disks that are coming today are not reliable.
AMIT AGARWAL
Old 06-09-2009, 08:53 AM   #8 (permalink)
Crowman
Krow's Avatar
Its upto your luck. So pray before you buy one. On your day you might just end up with an extremely solid reliable drive. Check warranty and buy accordingly. If you are adding HDD's, get 2x1tb insead of 1x2tb and backup all ur data on the second hdd.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 06-09-2009, 09:55 AM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
true. HDD crashes has become so commom these days. But that is only with Seagate. I haven't come up with any complaints on samsung or WD or hitachi hdds crashing.
Old 06-09-2009, 10:26 AM   #10 (permalink)
Crowman
Krow's Avatar
^rhitwick had a WD MyBook Essential 1TB External HDD crash on him and as a replacement he got the MyBook Mirror 1TB.
Krow is offline
Old 06-09-2009, 10:32 AM   #11 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ wow. forgot that. so, WD has joined the party.
Is this extremely high density perpendicular recording to blame. Ever since seagate started perpendicular recording on HDDs (from 7200.10), their HDD with high density (500Gb and higher) are failing.
Old 06-09-2009, 10:39 AM   #12 (permalink)
Crowman
Krow's Avatar
I am not familiar with the technical side of things so I can't comment on that, but in layman terms one can say that they tried to make flyovers for trucks with clay.
Krow is offline
