Old 31-08-2009, 01:52 PM   #1 (permalink)
geek........
Gauravs90's Avatar
Question SATA and PATA
Hi friends I'm really confused.
what is PATA and SATA hard drives? and what is the difference between them?.
Gauravs90 is offline
Old 01-09-2009, 12:33 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: SATA and PATA
here u go ---> http://findarticles.com/p/articles/m...2/ai_98977132/
and this too ---> http://blog.taragana.com/index.php/a...rives-a-guide/
in short and for begineers, Sata or Serial ATA is faster than PATA or Parallel ATA also SATA is newer (most recommended, be it SATA Hard disks or optical drives) and PATA was old technology..
the real boon of SATA comes into play when using RAID technology (for hard disks) but yes then there's SATA-I and SATA-II as well (with SATA-III jus around the corner)
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 01-09-2009, 01:37 PM   #3 (permalink)
geek........
Gauravs90's Avatar
thanks for the information
Old 01-09-2009, 01:51 PM   #4 (permalink)
not a problem dude..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 02-09-2009, 03:30 PM   #5 (permalink)
Here's a more detailed explanation:
PATA stands for Parallel Advanced Technology Attachment and is an interface (connection) used to connect storage devices (primarily hard disk drives). This is an older interface where the data is transmitted to and from the HDD parallely. The Newer SATA (Serial ATA) transmits data serially. Although parallel transmission was considered to be faster, the newer SATA interface transmits data faster than the combined transmission speed of the all the lanes of the PATA interface. Hence, the newer hard disks come with the SATA interface. And the SATA cable also helps reduce obstruction to airflow compared to the flat ribbon cable used for PATA. This allows for efficient cooling of devices inside the case. Although SATA was designed for both Data and Power in the same cable, it is not perfected and today’s HDDs use a separate molex connector for power. These are the differences. If all the above sounded like gibberish, just know this that SATA is better and faster than PATA.
otpsurvive is offline
Old 03-09-2009, 06:56 PM   #6 (permalink)
666
solomon_paulraj's Avatar
^^ nice one..
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
