Old 26-08-2009, 11:50 PM   #1 (permalink)
Default Pen drive compatibility
My pc is a old one which has USB 1.1 specification. I recently bought 8GB pen drive (transcend). Whenever I plug in the pen drive to usb drive windows says to install software. my system has XP SP2 so it should automatically detect the pen drive(It works in other USB 2.0 computers). When I plug in my old 1GB pen drive it detects and works fine. Is there any compatibility issue that USB 1.1 do not accepts nore than certain size limit?
Guhan
guhanath is offline
Old 27-08-2009, 05:16 PM   #2 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Re: Pen drive compatibility
as such there is no such issue... i am able 2 access my 250gb portable hdd with usb 1.1. get it replaced.
ankushkool is offline
Old 27-08-2009, 06:40 PM   #3 (permalink)
geek........
Gauravs90's Avatar
there is no compatibility problem, only transfer speed will be much slower than usb 2.0
Gauravs90 is offline
