Old 26-08-2009, 11:35 PM   #1 (permalink)
Default dell pc restore
hi all !
my system crashed with blue screen-restart loop ! so i tried system restore [didn't work], dell factory restore [didn't work], finally i formated c: and performed clean install, later i found out the problem was graphics card [which is solved after cleaning it thoroughly and reinstalling].
so now my problem is i lost the option of dell factory image restore which used to came up after pressing F8. i think it is because i formattted c:
but the another partition called "E:RECOVERY" is untouched since i purchaed the computer. it contains the complete file structure as original DELL used to have. also there is file "factory.wim" [E:\DELL\IMAGE\factory.wim] can anybody tell how to deploy this file? i know dell factory restore utility uses this factory.wim file to restore the pc. is there any way to make it work !
thanks in advance.
Amit Dutt
amit dutt is offline
Old 27-08-2009, 06:45 PM   #2 (permalink)
geek........
Gauravs90's Avatar
Default Re: dell pc restore
check in computer manual, there must be steps to how to restore os or call the dell hotline.
Gauravs90 is offline
Old 29-08-2009, 02:21 AM   #3 (permalink)
evewin89's Avatar
don't worry abt. that factory restore tool. i have dell inspiron 1525 which comes with vista. later i formatted my lappy and installed win7 and XP coz for me vista sucks.most of the time these tools proves to be a waste of disk space. when any problems arises these tools fails to restore the p.c. make back up of ur data's in some other medium. eg. dvd.
Evil Lives 4ever......
evewin89 is offline
