Old 23-08-2009, 09:01 PM   #1 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Default Auto Scrolling of Page
Recently I am facing a problem. The problem is when I open any page in any program such as Ms Word, Excel, Notepad, any browser like Mozila, Chrome, IE, the page automatically scroll down to the end of page. Whenever I try to scroll the page to the desired position, I could not stop the page. I checked the system with Antivirus, but there is no problem found.
My system is duel boot system with Win XP SP-3 and Windows 7. In both the OS I am facing same problem. Even in the safe mode the problem is same.
Is it a virus problem or Hardware problem? Otherwise my system is 100% OK.
Please give me some light to solve the problem with out formating the OS.
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 23-08-2009, 11:06 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Cool Re: Auto Scrolling of Page
A very possible guess: try to check if ur mouse's middle button is somehow pressed down.
Its a default property of mouse for auto scroll.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 24-08-2009, 10:41 PM   #3 (permalink)
geek........
Gauravs90's Avatar
Default Re: Auto Scrolling of Page
try disconnecting first keyboard and check if problem persist, if yes then try disconnecting mouse and check if problem persist, if yes then your computer have internal problem.
thx
Gauravs90 is offline
Old 25-08-2009, 08:59 AM   #4 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Thanks both of you. You are both right. The problem is with the mouse. As soon as I changed the mouse the problem is solved.
