Old 12-09-2004, 12:27 AM   #1 (permalink)
sms_solver's Avatar
Default Is there any sw that i am looking for?
Does anyone knows about any software that copies only folder structure from source (let say CD) to destination folder (i.e in Hard disk). I don't want files to be copied.
If there is not such kind of software, can anybody give hints or codes to do so in Visual Basic or C++.
Thanks,
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 12-09-2004, 09:53 AM   #2 (permalink)
You can do that very easily using a dos command called"XCOPY".
The syntax is
XCOPY source [destination] /T [/E]
You should go to your destination point, and open a dos window there, or open a dos window and go to your destination point, whichever is easier.
and enter the above command, where source is the folder you want to copy. In this case you can leave the destination out. but put /T after a space.
XCOPY H:\MyFolder\ /T
That will copy the directory structure but leave out empty sub-dirs at the source. However if you also add the /E as shown, it will include even the empty sub-dirs.
Hope that helped.
Amitava Das Gupta
adeegee is offline
Old 13-09-2004, 01:46 AM   #3 (permalink)
sms_solver's Avatar
Default thanks
thanks for solution
it will really going to help me a lot
but is there any window app that can do the same!
[ॐ एसएमएस॰सोल्भर ॐ]
Old 13-09-2004, 02:18 AM   #4 (permalink)
alib_i's Avatar
"WhereIsIt?" is the exact thing you need.
Its a software to keep track of your CD collection.
Its really good software, with features to search the entire collection.
Found it on DIGIT CD once.
its shareware btw
-Metallica
alib_i is offline
Old 13-09-2004, 02:21 AM   #5 (permalink)
You could write your own app that just calls this one in the background. Maybe using the Shell command in VB
ineo is offline
- by Anorion
- by ax3
