Originally Posted by chwamiki
hey! guys.
i have bought a new webcam(LOGITECH).i cannt use it on Y! messenger.dis is because it displays dis: no camera connected.
hows dis possible.i clicked lots of pics from the cam after dat it worked perfectly.
when i previously tried Y! displayed dat i was behind a firewall and thus i couldnt use the webcam.(I USE AVAST).i switched of avast protection.but still the same prob i was behind a firewall and thus i ....so please find me a solution guys.
hi
login to ur yahoo messenger.. and check out for the preferences option in the messenger tab..
check the correct option in it... such as no proxies, firewall wid proxies..etc
and connect ur webcam....
hope ur pblm will be solved
Vimal
