I need help with the Upgradation of my PC
I'm interested in buying an AMD Athlon 64 with MOBO & RAM. I have a samsung 5400rpm P-ATA HDD. Do I need to change the HDD to SATA?
I'm a casual gamer and I would like to RIP DVD's using the new system.
The only thing I have decided is to have 1Gb of DDR 400 RAM.
Please tell me the best config of Processor & MOBO (
With PCIe support). I live in Hyderabad & having enquired at various Hardware dealerships, I have found the prices of the dealer recommended config.
AMD Athlon 64 3200+ (939 pin) : Rs. 5,050/-
MOBO : MSI RS480M2 : Rs. 4,650/-
RAM : 1Gb DDR400 : Rs. 2,900/- (Mfr. was not specified).
CABINET : Mercury/Zebronics: Rs. 850/- (with 400W supply).
HDD : 160Gb SATA : Rs. 4,300/-
TOTAL : Rs. 17,750/-
Do you think that is the config I should go for, Also what is the Price Diff btw the Athlon 64 & Athlon 64FX ?
which is the better one?
I had just been to the AMD website & there was another processor called Athlon 64+X2, which is a dual core processor. Is this processor available in India?
Also would it be cheaper to get my system in hyderabad or should it be chennai?
I have heard that AMD were the cheapest in Chennai.
Please advice.
