Old 11-08-2009, 10:29 PM   #1 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Unhappy Problem with utorrent......plz help
In utorrent my upload speed is more than download speed.
When I try to limit the upload speed from Right Click on Torrent>Bandwidth Allocation>Set Upload Limit>(to some speed) my download speed decreases.
When I revert it to unlimited the download speed becomes normal.
What should I do to get more download speed than upload speed???
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 12-08-2009, 09:08 AM   #2 (permalink)
What? Where? How?
escape7's Avatar
Default Re: Problem with utorrent......plz help
You can't change your download speed as it is set by your service provider(the tech that they have... not much imo).
Also, if i'm not wrong upload speed =4*download speed. (can someone confirm that?)
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 12-08-2009, 09:55 AM   #3 (permalink)
ADSL lines have different upload and download speeds. Generally upload speeds are less than download speeds. Because people do not require uploading speeds. Its only required by servers and all. So I am not sure about the 4xdownload speed. Do a speed test from any of the websites and you would find that the upload speed is way less than the download speed!
hell_storm2006 is offline
Old 18-08-2009, 06:15 AM   #4 (permalink)
you could try azureus vuze which as a scheduler which works automatically and works like a charm for me. its a little heavy on the resources though.
and no, upload speed and download speed of your isp has nothing to do with your torrent clients (of course the max speed is limited).
some trackers recognize the share ratio intermittently and block peers, I suppose.
It doesn't happen with all torrents.
best.
legolas is offline
Old 18-08-2009, 06:33 AM   #5 (permalink)
Cool Buddy's Avatar
Does this happen for any torrent that you add? or is it a problem with some specific torrents?
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 18-08-2009, 11:00 AM   #6 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
It also depends on the file you are downloading.
If you are using BSNL you can have a look at the following url for router configuration
http://classictutorials.com/2007/08/...wnload-speeds/
This really helps
Blogging @ http://classictutorials.com
the.kaushik is offline
