Old 29-06-2005, 01:42 PM   #1 (permalink)
nipun_the_gr8
Posts: n/a
Default Zone Alarm Security Suite 5.5.062.011 Issue
I have ZoneAlarm Security Suite v5.5.062.011. The problem is that
Outlook Express stops working after I install it (i.e. I am unable to
send/receive any message & it shows errors)( )
Please help me regarding this issue.
Thanks in advance !!
Old 29-06-2005, 01:55 PM   #2 (permalink)
GameAddict's Avatar
My best guess is that, ZA is blocking OE from accessing net.Check the ZA log and/or put the OE under "Safe Programs/Ports to connect to net" list in ZA.
GA
GameAddict is offline
Old 29-06-2005, 06:15 PM   #3 (permalink)
Certified Nutz
sreevirus's Avatar
since u r using the security suite, try this:
open the ZASS window, go to program control, browse to the Outlook Express entry and verify if the options for Access, Server and Send Mail are checked.
next, go to Email Protection and try turning off the Junk Email filter.
if that doesnt work try turning off all inbound and outbound mailsafe protection.
"Don't take life too seriously. You'll never get out alive!" - Bugs Bunny
sreevirus is offline
Old 30-06-2005, 12:29 AM   #4 (permalink)
Ashwin Saxena
Posts: n/a
Well this is the best suggestion.
