Old 29-06-2005, 05:31 AM   #1 (permalink)
Default Traffic flow on dial up
When a dial up is connected, two computers show up at the right corner of the taskbar. One of them denotes the traffic received and the other, the traffic sent. After some time on a dial up, i've noticed that even though the connection has not been terminated,and though u've not stopped browsing, traffic ceases to flow. This goes on for sometime and then either traffic starts flowing again or you disconnect in frustration. I've read somewhere that this is called 'idle time'.
My question is, Is this idle time fair? Is there any way to get rid of 'idle time'?
HELP!
If ur not livin on d edge, ur wastin space
shefzomania is offline
Old 29-06-2005, 07:50 AM   #2 (permalink)
q3_abhi's Avatar
Well,I dont know about "Idle time", but i have heard that something is being downloaded in the background (data trnaspher). Dont know it is true or not.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 29-06-2005, 10:07 AM   #3 (permalink)
http://www.dlink.co.in/dlink/Product.../dfm562e++.htm
came across a few modem that has got "Flow Control "
check out this modem also can identify caller id dtmf format(worked fine at blore)
vijaythefool is offline
Old 30-06-2005, 01:12 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
yep, dial-up conncetions do go 'idle'. use connectionkeeper.
click & download http://www.download.com/Connection-K...l?tag=lst-0-16
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 30-06-2005, 03:09 PM   #5 (permalink)
expertno.1's Avatar
dude the server cannot send you data continuously due to load upon it
u try it at night and there will be almost no idle time
and in day when server is busy it does requests of all the computers and in that way it stops for 2-3 seconds and then comes back
this is normal
this is the major problem for the dialup users
expertno.1 is offline
Old 30-06-2005, 11:20 PM   #6 (permalink)
godsownman's Avatar
I get an idle time of sometime over 3 minutes and in frusttation I have to disconnect and reconnect.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 03-07-2005, 12:44 PM   #7 (permalink)
Thnx for the info guys. Gr8 help
