25-07-2009, 12:09 PM
XLr8
tough cleaning
hello people,
can anyone tell me how to clean the PCI Express slot of my MB ????
25-07-2009, 12:30 PM
Bond, Desi Bond!
Re: tough cleaning
Use either air blower or paint brush. Do not use anything wet.
25-07-2009, 12:31 PM
Re: tough cleaning
i think u need a AIR-BLOWER
25-07-2009, 02:48 PM
XLr8
Re: tough cleaning
i tried a paint brush but i see some thermocol on its base.
i need something to clean the contacts and also to extract the bits so that the card fits in properly.
25-07-2009, 08:06 PM
15.0 GHz
Re: tough cleaning
use an air-blower not a vacuum cleaner
25-07-2009, 11:16 PM
Bond, Desi Bond!
Re: tough cleaning
if you have tongs (small ones), you can use them to extract thermocol bits
but be careful
26-07-2009, 01:13 AM
XLr8
Re: tough cleaning
ok,
i am going to try small, fine tweeser
26-07-2009, 04:32 AM
Wire muncher!
Re: tough cleaning
I'd advise against using a paint brush. The hair can get inside the slot. I'd advise you to buy a can of compressed air and use it to clean the slot. In fact you can use this to clean any electronic component inside the computer.
29-07-2009, 03:50 PM
XLr8
Re: tough cleaning
done it sucessfully by using a air blower.
thanx people...
29-07-2009, 07:47 PM
Re: tough cleaning
what kind of shops keep an air blower?i want to buy one.
View my Portfolio here-
Pixels and Polygons | On Linkedin | On Facebook
Available for freelance. PM me for details.
MSI 890 GXM G65, Phenom X6 1055T, G.Skill 1600Mhz "Ripjaws" 2x2gb Kit, MSI GTX 470, WD Black 500Gb, NZXT Gamma, Corsair Vx550, Hp 22x DVD-Rw, Benq G2420HD, Logitech Mx-518, Xbox 360 Gamepad for PC
30-07-2009, 11:46 PM
Re: tough cleaning
I also want to know, regarding air blower shops
31-07-2009, 04:25 AM
Wire muncher!
Re: tough cleaning
Whats an air blower, btw???
31-07-2009, 08:38 AM
Re: tough cleaning
this is- Image
Search this Thread |
