Old 23-07-2009, 07:39 PM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Default Strange Connectivity Issue
In my Dell Studio 15 laptop, whenever I access the the public WiFi network of my computer center, it works but as soon as I plug in the Cross-LAN cable to share the same Internet and network, my laptop disconnects from Internet as it gives precedence to LAN card over WiFi. Anyway to keep them both working and thus sharing the same network between the 2 ?
Plasma_Snake is offline
Old 23-07-2009, 11:10 PM   #2 (permalink)
din
Tribal Boy
din's Avatar
Default Re: Strange Connectivity Issue
Just curious - The wifi in your computer center is provided just for internet and not for internal network ?
din is offline
Old 23-07-2009, 11:52 PM   #3 (permalink)
Indidiot
Its for both. I'm using Vista and when I connect via WiFi, the Connection Center shows Internet connectivity but as soon as I plug in the LAN cable in the Ethernet port, its doesn't disconnects the WiFi connection but shows no Internet connectivity.
Old 24-07-2009, 04:18 PM   #4 (permalink)
din
Tribal Boy
din's Avatar
OK, if it is for both, I mean internet plus internal network access, why using LAN cable ?
I know you asked for a solution of using wi-fi and LAN and this is not the exact answer, but just checking why you are not using wi-fi for both ?
din is offline
Old 24-07-2009, 05:46 PM   #5 (permalink)
Indidiot
Look, there r 2 floors. Lower floor has full Internet and LAN connectivity while upper has only LAN and that too independent, it is not connected to the LAN of the lower floor. What I want to do is to use the Internet from the lower LAN thru my laptop's WiFi and provide access to the computers of the upper LAN via my laptop's Ethernet. Configuring it further ain't the problem, THE problem is to get both the networks working simultaneously.
