Old 28-06-2005, 12:59 PM   #1 (permalink)
QA Juggler
saROMan's Avatar
Default New Problem !!!
Ok as nothing had happned i had to format the system..and reinstall Xp..so now after installing every thing...when i connect to Net suddenly i Get BSOD..and machine restarts..so went to services..and did some tweaking..and now the scenario has changed..now Inet runs smoothly..but after 15-30 Min..suddnly i get the BSOD and PC restarts...so after doing some reasearch i have Found out that 2 Services are causing the problem they are as follows...
1st My System Log
Warning 6/28/2005 7:29:13 AM Dhcp None 1007 N/A
Warning 6/27/2005 10:26:33 PM Dhcp None 1007 N/A
Warning 6/27/2005 10:17:23 PM Tcpip None 4226 N/A
Warning 6/27/2005 10:01:49 PM Dhcp None 1007 N/A
Warning 6/27/2005 9:40:15 PM Dhcp None 1007 N/A
Warning 6/27/2005 8:21:34 PM Dhcp None 1007 N/A
Warning 6/27/2005 8:05:22 PM Dhcp None 1007 N/A
Warning 6/27/2005 7:59:43 PM Dhcp None 1007 N/A
Warning 6/27/2005 7:45:00 PM Dhcp None 1007 N/A
Warning 6/27/2005 7:41:49 PM Dhcp None 1007 N/A
Warning 6/27/2005 7:03:29 PM Dhcp None 1007 N/A
Warning 6/27/2005 6:30:51 PM Dhcp None 1007 N/A
Warning 6/27/2005 6:27:41 PM Dhcp None 1007 N/A
Warning 6/27/2005 6:26:10 PM Dhcp None 1007 N/A
Error 6/28/2005 7:27:30 AM acpi None 4 N/A
Error 6/28/2005 7:27:30 AM acpi None 5 N/A
Error 6/27/2005 10:47:13 PM W32Time None 29 N/A
Error 6/27/2005 10:47:13 PM W32Time None 17 N/A
Error 6/27/2005 10:41:55 PM W32Time None 29 N/A
Error 6/27/2005 10:41:55 PM W32Time None 17 N/A
Error 6/27/2005 10:26:51 PM W32Time None 29 N/A
Error 6/27/2005 10:26:51 PM W32Time None 17 N/A
Error 6/27/2005 10:22:30 PM acpi None 4 N/A
Error 6/27/2005 10:22:30 PM acpi None 5 N/A
Error 6/27/2005 10:10:27 PM W32Time None 29 N/A
Error 6/27/2005 10:10:27 PM W32Time None 17 N/A
Error 6/27/2005 10:02:08 PM W32Time None 29 N/A
Error 6/27/2005 10:02:08 PM W32Time None 17 N/A
Error 6/27/2005 10:02:06 PM W32Time None 29 N/A
Error 6/27/2005 10:02:06 PM W32Time None 17 N/A
Error 6/27/2005 9:57:47 PM acpi None 4 N/A
Error 6/27/2005 9:57:47 PM acpi None 5 N/A
Error 6/27/2005 9:40:34 PM W32Time None 29 N/A
Error 6/27/2005 9:40:34 PM W32Time None 17 N/A
Error 6/27/2005 9:40:30 PM W32Time None 29 N/A
Error 6/27/2005 9:40:30 PM W32Time None 17 N/A
Error 6/27/2005 9:37:14 PM acpi None 4 N/A
Error 6/27/2005 9:37:14 PM acpi None 5 N/A
Error 6/27/2005 9:36:26 PM DCOM None 10005 One
Error 6/27/2005 9:06:53 PM W32Time None 29 N/A
Error 6/27/2005 9:06:53 PM W32Time None 17 N/A
Error 6/27/2005 8:36:52 PM W32Time None 29 N/A
Error 6/27/2005 8:36:52 PM W32Time None 17 N/A
Error 6/27/2005 8:21:51 PM W32Time None 29 N/A
Error 6/27/2005 8:21:51 PM W32Time None 17 N/A
Error 6/27/2005 8:17:25 PM acpi None 4 N/A
Error 6/27/2005 8:17:25 PM acpi None 5 N/A
Error 6/27/2005 8:05:36 PM W32Time None 29 N/A
Error 6/27/2005 8:05:36 PM W32Time None 17 N/A
Error 6/27/2005 8:05:35 PM W32Time None 29 N/A
Error 6/27/2005 8:05:35 PM W32Time None 17 N/A
Error 6/27/2005 8:03:24 PM acpi None 4 N/A
Error 6/27/2005 8:03:24 PM acpi None 5 N/A
Error 6/27/2005 8:00:05 PM W32Time None 29 N/A
Error 6/27/2005 8:00:05 PM W32Time None 17 N/A
Error 6/27/2005 8:00:03 PM W32Time None 29 N/A
Error 6/27/2005 8:00:03 PM W32Time None 17 N/A
Error 6/27/2005 7:57:52 PM acpi None 4 N/A
Error 6/27/2005 7:57:52 PM acpi None 5 N/A
Error 6/27/2005 7:45:00 PM W32Time None 29 N/A
Error 6/27/2005 7:45:00 PM W32Time None 17 N/A
Error 6/27/2005 7:41:49 PM W32Time None 29 N/A
Error 6/27/2005 7:41:49 PM W32Time None 17 N/A
Error 6/27/2005 7:18:42 PM W32Time None 29 N/A
Error 6/27/2005 7:18:42 PM W32Time None 17 N/A
Error 6/27/2005 7:03:42 PM W32Time None 29 N/A
Error 6/27/2005 7:03:42 PM W32Time None 17 N/A
Error 6/27/2005 7:03:40 PM W32Time None 29 N/A
Error 6/27/2005 7:03:39 PM W32Time None 17 N/A
Error 6/27/2005 7:00:54 PM acpi None 4 N/A
Error 6/27/2005 7:00:54 PM acpi None 5 N/A
Error 6/27/2005 11:39:32 PM acpi None 4 N/A
Error 6/27/2005 11:39:32 PM acpi None 5 N/A
These 2 Services are...
ACPI
AMLI: ACPI BIOS is attempting to read from an illegal IO port address (0x71), which lies in the 0x70 - 0x71 protected address range. This could lead to system instability. Please contact your system vendor for technical assistance.
W32Time
Time Provider NtpClient: An error occurred during DNS lookup of the manually configured peer 'time.windows.com,0x1'. NtpClient will try the DNS lookup again in 15 minutes. The error was: A socket operation was attempted to an unreachable host. (0x80072751)
Now Google says 1st Error is due to Power Managment and Gaved this info.
ACPI evolves the existing collection of power management BIOS code, Advanced Power Management (APM) application programming interfaces (APIs, PNPBIOS APIs, Multiprocessor Specification (MPS) tables and so on into a well-defined power management and configuration interface specification.
..so have switched to Always on pofile...and 2nd is Syncronization problem...and cant find the solution for it...
Any Kind of Help is really Appreciated ....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 28-06-2005, 01:07 PM   #2 (permalink)
vishal_bhatia87
Posts: n/a
Double click on the clock
Selet the tab 'Internet Time'
Uncheck the box that say 'Automatically Syncronize with an internet time server'
Press Apply
Press OK
Restart
Old 28-06-2005, 03:10 PM   #3 (permalink)
vishal_bhatia87
Posts: n/a
Is your problem solved?
Old 28-06-2005, 08:18 PM   #4 (permalink)
QA Juggler
saROMan's Avatar
well i did a System restore to earlier Time..and seems the problem is solved...any ways ....thx vishal_bhatia87 for the advice..but i have already done that...any ways i appreciate ur efforts ...
saROMan is offline
