Old 28-06-2005, 11:28 AM   #1 (permalink)
Default Out Of Frenqncy
Hi, everbody,
i m using winme from last 2 days i was unable to start my pc as soon as i start monitor displays out of frenqency and then it counts down and shuts
whats problem i am confused can any body help me its urgent
dikudik is offline
Old 28-06-2005, 12:12 PM   #2 (permalink)
PROBLEM IS YOUR REFRESH RATE AND RESOLUTION.
if u have prescribed a custom refresh rate :most cases over 60hz ::for your monitor, in your video cards settings, and the monitor will not be able to support that refresh rate in the given resolution, it simply goes into suspend mode, to avoid hardware damage.
To correct this, start in safe mode.. Press F8 while booting,and go to safe mode. correct the display settings,otherwise,remove monitor and video drivers.restart. reinstall the drivers. If still problem presists, u have to edit registry keys.
let me know if this helps.
Rajeev V Nair
premrajeev is offline
