Old 28-06-2005, 01:23 AM   #1 (permalink)
Default No sound in Pinnacle TV Tuner card
my sys config is- p4 1.7ghz, 256 rd ram, intel 850 mv motherboard
,128mb ati radeon 9200se agp card and the pinnacle pc tv stereo tuner card
i m using windows xp professional
now my problem is that when i start the tv tuner everything seems to be fine except the sound . i m unable to hear sound
i had replugged the hardware and reinstalled the windows 2 times
in device manager everthing is fine
but when i start the tv tuner application the sound doesn't work
one more thing i had purchased this card near about 2-3 months ago and i think in the first month the sound worked fine
now no sound is coming
please help me
thadhanihemant is offline
Old 28-06-2005, 12:09 PM   #2 (permalink)
Is the 'Line-in' in Volume Control muted? Check please. Also is there a loopback cable from the tv tuner card to your sound card?
paraman is offline
Old 28-06-2005, 12:22 PM   #3 (permalink)
2 solutions ..
1. check the loop back cable is connected correctly.. this will be a small cable to connect the audio out of your tuner card to the line in of your soundcard..connect it , open sound properties, mixer and check line in is not muted and volume level is adequate.
2.if u r supplied with no loopback cable,there will be another cable which connects to your soundcard..this will b like the round cable with molex connectors at both ends which is used in CD drives...so connect it to your tuner and the other end to your soundcard aux input...open sound properties and check wether the aux volume is adequate an d not muted..
(normally, this kind of connectors can be seen on high end tuners only...)
I think this should solve your worries...
let me know if this helps.
Rajeev V Nair
premrajeev is offline
